StangSuspension.com Your source for late model Ford Mustang suspension parts and performance!
Pinion snubber
Old May 4, 2006 | 03:09 PM
nasmscott's Avatar
nasmscott
Default Pinion snubber
I never see mention of changing the pinion snuber in the discussions of lowering. I have sportlines and Strange 10 way schocks/struts (bought it this way). The car just crashes over bumps (in rear) and adjusting the schocks helps little if at all. If the pinion snubber was stock, which by the dirt it appears to be, could that negatively affect the ride quality? If it needs to be replaced, what should I use? Thanks in advance.
Old May 4, 2006 | 04:04 PM
STANGSUSPENSION's Avatar
STANGSUSPENSION
Former Sponsor
Default RE: Pinion snubber
The pinion snubber is only in use when the car bottoms out completely... Its a last resort item in your suspension...
If your car is too low, and you feel that it is bottoming out (hitting the pinionsnubber/bumpstop), then you may want to get a shorter one.
If after you replace your stock bumpstop, the problem does not go away, I'd steer towards the shocks as the culprit...
Sincerely,
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
KingRando
Oct 2, 2015 08:06 AM
DJ Piner
Sep 30, 2015 03:03 PM
Urambo Tauro
Sep 7, 2015 12:47 PM
