StangSuspension.com Your source for late model Ford Mustang suspension parts and performance!
road noise
Old Jan 21, 2007 | 02:14 AM
bscottie's Avatar
bscottie
Default road noise
I got the BMR adjustable panhard bar and some BMR fixed LCA's both with the poly bushings, is there a quiter setup to help get rid of the added road noise?
Old Jan 22, 2007 | 07:31 PM
STANGSUSPENSION's Avatar
STANGSUSPENSION
Former Sponsor
Default RE: road noise
Polyurethane is usually quiet if greased properly..... I dont know of any softer compounds in any aftermarket products for the 05-07... other thane polyurethane...
Are you just hearing increased road noise?
Old Jan 23, 2007 | 01:42 AM
bscottie's Avatar
bscottie
Josh thanks for the reply here and the email, it seems it is probably a combination of both road noise and gear whine, quite honestly I have seen several opinions of what is normal greasing, but nothing from a part supplier/distributor. it may be worthwhile to take apart and clean them and start over
Old Jan 23, 2007 | 05:31 PM
STANGSUSPENSION
Former Sponsor
That is really all you can do, to see if that is the weak link in the install... Otherwise it may be just the result of stiffer bushings/components... hard to say over the Internet without driving in the car...
Old Jan 23, 2007 | 05:35 PM
P Zero's Avatar
P Zero
Polyeurathane WILL transfer more road noise than rubber. Because the polyeurathane bushings are solid, and theyre harder than rubber. Rubber absorbs more noise and vibration, but the downside of rubber is it also delfects (bends) a lot. We happen to have a car in the shop where a kid put in poly motor mounts. Well now theyre complaining that they can hear and feel A LOT more noise and vibration. To me is kind like duh, he basically put in solid motor mounts. Whats he expect?
-P.
KingRando
Oct 2, 2015 08:06 AM
folivier
Oct 2, 2015 05:34 AM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
guitarman376
Sep 30, 2015 05:54 PM
69Volunteer
Sep 30, 2015 10:39 AM
