StangSuspension.com Your source for late model Ford Mustang suspension parts and performance!
Need help please
Old Oct 28, 2007 | 10:42 PM
den2oo278's Avatar
den2oo278
Default Need help please
Alrite i have a 98 3.8 mustang that i have a problem with. For about 9 months my rear end has been bottomeing out. since this started i have installed monroe shocks.. then garbial shocks. ford c racings springs and still have the same problem. I thing i need a really stiff shock or something any ideas on what i should do. PLEASE help.. ill prob change all shocks and struts again to fix problem hopefully.. Its making me hate the love of my life lol. thanks
Old Oct 29, 2007 | 08:00 PM
STANGSUSPENSION's Avatar
STANGSUSPENSION
Former Sponsor
Default RE: Need help please
When its NOT bottoming out... what is the ride like? Does it seem to bottom out with ease? Not excessive suspension movement?
If so, you may just need a shorter pinion snubber (aka bumpstop). Here is a link... http://www.stangsuspension.com/store...?idproduct=609
If the ride seems bad AND its bottoming out... then you may just want to get better shocks in the rear, such as Tokico or Bilstein. Either way, a shorter bumpstop will help to keep it from bottoming out as easily, assuming your shocks are good...
Sincerely,
Old Nov 1, 2007 | 11:12 PM
den2oo278's Avatar
den2oo278
where are these bump stops located? please help me it seems if i hit any bump it bottoms out and its annoying. I thing imma upgrade my shocks and struts to the tockio blues but i think i need to change the bump stops too where are they located?>
Old Nov 2, 2007 | 09:29 PM
STANGSUSPENSION
Former Sponsor
Above the rear differential housing. Your stock one will look like a big block of rubber.
You just need one pinion snubber to replace your stock one...
Sincerely,
Old Nov 2, 2007 | 11:01 PM
den2oo278's Avatar
den2oo278
last question if i order the shocks and struts and rubber mount thing can i get a discount code ? please
Old Nov 5, 2007 | 07:47 PM
STANGSUSPENSION
Former Sponsor
We have sent a PM regarding the discount code...
