Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Cobra vs Stealth
Old May 9, 2004 | 03:19 AM
fox5.0's Avatar
fox5.0
Default Cobra vs Stealth
my brother has a dodge stealth twin turbo that has a new stage one long block and air filter, exhaust w/cats cut out, 6 puck clutch and pushing about 15psi. i was wondering how that would compare in a race with a 03 cobra with 2.93" underdrive pully and exhaust.
Old May 9, 2004 | 03:35 AM
Guest
Guest
Posts: n/a
Default RE: Cobra vs Stealth
Cobra would probably spank it. Stealth TTs are mid 13 cars cause of the massive weight of the car. (somewhere near 4000 lbs)
Old May 9, 2004 | 01:53 PM
SilverBullet5.0's Avatar
SilverBullet5.0
I ♥ Acer
im pretty sure that stock the stealths werent even in the 13's, even with the TT setup.....
Old May 9, 2004 | 03:52 PM
fox5.0's Avatar
fox5.0
yeah stock the stealth tt run mid 13's
Old May 9, 2004 | 08:23 PM
fox5.0's Avatar
fox5.0
His is a 95 (second gen) the 91-93 ran mid to high 13's and the 94-96 ran mid to low 13's stock. They are pigs when it comes to weight but the awd helps the get up and go from a dig. before he did the block and gutted cats he ran a 12.99 @106 with just filter and clutch. He is expecting to run mid to low 12's when its broken in
Old May 9, 2004 | 08:24 PM
SilverBullet5.0
I ♥ Acer
damn i never knew stealths could be that wicked, ill be watchin out for those now.....
Old May 10, 2004 | 11:23 AM
ShadowG03's Avatar
ShadowG03
Si is right you'll probably beat him 3000gt's and stealths weigh in at about 3800 roughly, damn that's a fat bitch.
Old May 10, 2004 | 01:42 PM
iwrxit's Avatar
iwrxit
if he was in the 12's before watchout. the turbo cars come alive w/o cats. for real.
Old May 11, 2004 | 03:18 AM
2000GT4.6's Avatar
2000GT4.6
I thought they were rated at 320 HP? Dunno what the torque rating was, but 320 hp and 4000 pounds does not equal 13.1s, even with AWD.
I dont think you can pull off the redline clutch dropping stuff the new WRXs etc can. Espcially considering this is a mitsubishi/dodge project, and neither brand can build a transmission for ****. (this is experence speaking here)
Old May 11, 2004 | 03:33 AM
Guest
Guest
Posts: n/a
OK so they're mid 13s to mid 14s depending on the model year.
1991 Dodge Stealth R/T Turbo 6.0 14.5
1992 Dodge Stealth R/T Turbo 5.7 14.2
1991 Mitsubishi 3000GT VR-4 5.3 13.8
1992 Mitsubishi 3000GT VR-4 5.8 14.3
1993 Mitsubishi 3000GT VR-4 5.3 14.0
1994 Mitsubishi 3000GT VR-4 5.7 14.2
1995 Mitsubishi 3000GT VR-4 5.4 13.5
1997 Mitsubishi 3000GT VR-4 4.8 13.6
