The Beast has arrived!
ORIGINAL: Ride Of The Month
no offense, but it doesnt seem that you exactly scratching your *** for cash...it seems that you could probably afford one...no?
ORIGINAL: eindow
Congrats MrRogers[sm=icon_cheers.gif], I see your in Pasadena we definately need to hook up someday so I could take alook at that badboy
...But lets do it somtime after september just to make it interesting[sm=badbadbad.gif]...
BTW, I'm still Jealous[8D]...
...But lets do it somtime after september just to make it interesting[sm=badbadbad.gif]...BTW, I'm still Jealous[8D]...
...That Z06 does look nice in black..[:-]
ORIGINAL: eindow
Co'mon Ride you know I'm broke
ORIGINAL: eindow
ORIGINAL: MrRogers
I had to get black. I passed on two other Z06s that were not the right color. The exhaust note is more silent than a mini van at cruising speeds. WOT sounds decent but I need more roar. So next month i'm going to throw on a B&B bullet prt exhaust system...that should wake her up some...
ORIGINAL: eindow
Just get some LT-Headers & keep the stock exhaust you'll pick up more HP and it will sound alot better...
ORIGINAL: MrRogers
Work a thermal vacuum test on the graveyard shift...gives a lot of time to read basically every thread...[sm=sleeping.gif]
^ Oh, if you don't know what that is, imagine a 1 degree temp change taking 30 minutes...then change 100 degrees...But at least I worked on stuff that is cruising on Mars.
How's that for frequent flyer miles?
ORIGINAL: MrRogers
Usualy that would work but the Z06 exhaust has butterfly springs that won't open up until you reach a certain Rpm.. So I have to get rid of the factory mufflers. Since the Z06 comes with 3in tubing from the factory, b&b mufflers should do the trick...
ORIGINAL: eindow
ORIGINAL: MrRogers
