Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Drag racing In Texas
Old Oct 10, 2006 | 12:04 AM
ballstix's Avatar
ballstix
Default Drag racing In Texas
Hi guys, ive got a friend with a turbo Civic that ive been trying to beat in the 1/4 but I cant break 14's I have gotten a 15.1 and 15 flat. I know my car can do better also ive not been able to really launch due to my street tires. Well my question is how much time can I expect to drop if I get a set of drag tires? Also I am a very new drag guy but im trying to pick it up quick.
Old Oct 10, 2006 | 12:30 AM
Quick Shot xMLx's Avatar
Quick Shot xMLx
Default RE: Drag racing In Texas
I saw that in your profile it said you have an 87. Is it a 5spd or auto? Bolt-ons with gears along with some good tires might be enough to beat your friend depending on what setup hes running. Is your car in good shape or is it a bit tired?
Old Oct 10, 2006 | 12:37 AM
ballstix's Avatar
ballstix
All it really has on it is 3.73's and upper/lower intake headers/flowmasters. It is a 5 speed then engine runs strong I start to pull him back in half track but I cant get off the line it smokes the tires even if im already rolling.
Old Oct 10, 2006 | 02:23 AM
Sean W.'s Avatar
Sean W.
try to get a high performance fuel pump and a set of damn good spark plugs. that should give you an extra getty up. you unleash the beast if its not getting fed right. gotta give it more gas. and a nice pair of drag tires.
Old Oct 10, 2006 | 02:39 AM
Quick Shot xMLx
ORIGINAL: ballstix
If you start pulling back it sounds like you need some better tires or perhaps some practice launching. Either way get some nicer tires and I'm sure that you'll be able to out-launch his fwd.
Old Oct 10, 2006 | 02:46 AM
HC_CrAzYHoRsE's Avatar
HC_CrAzYHoRsE
ORIGINAL: ballstix
well my friend you answered your own question, there's something really fuggered up going on right there. you have rear wheel drive, he has front wheel drive, he has turbo lag and you have instant torque. if you start reeling him in at half track, then you have to work on the launches. if his car actually had more power than you, you wouldn't be catching up... he'd be pulling further, not the other way around. start with some good drag radials and practice practice practice, that's all there is to it... unless he's running slicks and has a bunch of suspension work, you should easily get him out of the hole, and then just keep pulling.
Old Oct 10, 2006 | 01:17 PM
92hatchLX's Avatar
92hatchLX
What altitude is your track at???? A good set of sticky tires and gears should do the trick for ya.
Old Oct 10, 2006 | 01:38 PM
fordguy17's Avatar
fordguy17
ORIGINAL: Sean W.
the stock fuel setup is good to about 270 rwhp. he isn't even running close to that. spark plugs are not going to make a difference in his application.
like others mentioned he just needs to get off the line.
Old Oct 10, 2006 | 02:05 PM
dimebag's Avatar
dimebag
yea man i have an 88 and stock i ran 14.7... tho my altitude may be lower than yours, i dunno. either way, i think stock you can get more outa that, and w. gears and the other things you mentioned you should be low-mid 14s i believe... w. drs and a good launch... i wanna say high 13s?<someone can verify that tho, im just going on what i know.
Old Oct 10, 2006 | 07:22 PM
Mustang Boy's Avatar
Mustang Boy
wut RPM r u launching at cause it sounds like ur launching at too high of an RPM and how r u taking ur clutch off r u just droppin it or r u feathering it off
