Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Looking for input on mods
Old Jul 9, 2003 | 02:50 AM
hawks05's Avatar
hawks05
Default Looking for input on mods
what r the best things i can do to get more power for my car i heard that getting the 99+ heads would add about 50+hp what else can i get and if possible can you list prices.
any and all help is appericated thanks.
Old Jul 9, 2003 | 01:58 PM
EvilKenevil's Avatar
EvilKenevil
If you are gonna spend the money to get heads get a good set of aftermarket heads, not just the newer ones.
Old Jul 9, 2003 | 04:15 PM
Zcpeanut's Avatar
Zcpeanut
You can get a 50 shot of N20, it might be a bit expensive, and some people dont agree with n20 but some of the things jeepster and others have said about it have convinced me
Old Jul 10, 2003 | 02:05 PM
EvilKenevil
Yeah, a couple of months ago i was against N2O but then after reading some of the posts by the people that have nitrous i am changing my mind, as a matter of fact i am doing research on the different kits to find the best one to put on my car (with limited other mods) </P>
any suggestions <IMG src=smileys/smiley1.gif border="0"></P>
Old Jul 10, 2003 | 02:10 PM
WhiteHawk's Avatar
WhiteHawk
N20 is not bad, one, it's been developed nicely over the years and 2 if you stick to the cautions (do's and don'ts), obey and respect them and KNOW how and why the product works it's probably one of the cheapest ways to get ALOT of horses.
Old Jul 10, 2003 | 02:18 PM
Sean's Avatar
Sean
I would also like to install it,but i think for the street and daily use boost will be better.
Old Jul 10, 2003 | 02:21 PM
WhiteHawk's Avatar
WhiteHawk
I agree, if its a daily driver then boost is the way to go.
Old Jul 10, 2003 | 03:33 PM
Zcpeanut's Avatar
Zcpeanut
</P>
ya my aunt sells horses up in trabuco! theyre expensive!!, hehe j/k but whitehawk, what are you talking about when you say "boost"?</P>
Old Jul 12, 2003 | 07:32 AM
robwazhere's Avatar
robwazhere
boost is air forced into the motor via turbo or supercharger
Old Jul 13, 2003 | 02:20 AM
jeep45238's Avatar
jeep45238
I ♥ Acer
Forced induction, like superchargers and turbochargeres.
They create positive PSI (boost) and forces more air than usual into the motor (forced induction).
Nitrous is also forced induction, since it puts more oxygen in the motor than what it would usually take in.
I disagree with the "boost is better for daily driver" theory.
Why? Simply put, it's a waste of money for the most part. On a daily driver, you take it to work, do groceries, blah blah blah blah blah. For cheap power, nitrous is THE KEY in any car. The biggest gains for the dollar are seen with N20. The wear and tear of boost is always there when the motor's running under load (driving). The wear and tear of nitrous is only there when the button is pushed, which is usually at the track or short street races.
From the sound of hawks05 question, he doesn't have the monetary funds to do boost, but nitrous is easily had.
You can get a very nice nitrous set up for under $700, bottle, silinoids, lines, blow down tube (very important safety feature), and a heater for the bottle. That $700 will give you over 100 horses if your motor can take it (I strongly suggest you don't go over 75 in that V6).
Don't buy used unless you plan on rebuilding the silinoids. Always use a filter before each silinoid.
Always do wet when possible, it doesn't rely upon the stock fuel system to keep the motor from gernading (it supplies the additional gasoline itself). Only spray at wide open throttle, when the motor can easily rev (not 25 mph in 5th...), and never below 2500 or above redline.
My personal favorite: NX.
https://mustangforums.com/forum_posts.asp?TID=1751&PN=2
