Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Common modding terms
Old Nov 12, 2006 | 03:47 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default Common modding terms
Since there has been some confusion as of late about what certain terms mean when it comes to modding cars, I hope this clears up things a bit.
"Cam only"...This refers to an engine in which the only INTERNAL mod has been the cam, the car can and should have other supporting mods, including exhaust, gears and a stall if the car is auto.
"Bolt ons"...This refers to any mod that does not require going into the engine. Headers, cat backs, underdrive pulley, CAI's, gears and intakes are all bolt on's.
"Internally stock"...Means that the short block (block, rods and pistons) are stock. The heads can be swaped as well as having anyother mods. The key here is that the internals are stock.
Hope this helps avoid members misunderstanding things. I will add to this if I forgot some.
Old Nov 12, 2006 | 05:10 PM
Rusmisel01GT's Avatar
Rusmisel01GT
Default RE: Common modding terms
Should just say full bolt-ons/cam [8D]
j/k
Old Nov 30, 2006 | 03:44 PM
itzztrick's Avatar
itzztrick
Isn't there a site with all the definitions?
Old Nov 30, 2006 | 07:17 PM
MrMiracle's Avatar
MrMiracle
Might want to throw in blown, sprayed, gears, and tuned.
Old Nov 30, 2006 | 07:21 PM
Demon 340's Avatar
Demon 340
Administrator
ive put together a glossary of terms...we are working on the coding to get it live.
Old Nov 30, 2006 | 08:17 PM
Sleeper05's Avatar
Sleeper05
ORIGINAL: MrMiracle
...or FI, juiced, 4.10s, and dyno'd...
dont forget tubbed, dropped, stripped, etc for non-hp/tq mods
Old Dec 2, 2006 | 10:09 PM
JD1969's Avatar
JD1969
Good info guys keep it coming.
Old Dec 2, 2006 | 10:18 PM
WRXtranceformed's Avatar
WRXtranceformed
Boosted!!
Old Dec 2, 2006 | 11:13 PM
Sleeper05's Avatar
Sleeper05
"bar" refers to the measurement of one atmospheric pressure of boost, which is 14.7psi
"lean" means the motor is not getting enough fuel
"rich" means the motor is getting too much fuel
"vht" is an additive put on race track surfaces to make them stickier, and it burned my eyes today
Old Feb 3, 2007 | 08:24 PM
hellas85stang's Avatar
hellas85stang
stroked n poked,
