About what is the ET that most tracks require a roll cage. Does it vary from track to track or is their a universal et? right now im required to wear a helmet, wondering when ill need the roll cage
For your car both NHRA and IHRA will require a 5 point roll bar at 11.49 (nobody ever bothers with a 5 point, they just do a 6 point).
Unsanctioned tracks may be more or less strict.
Here is a link to some NHRA quick tech http://www.nhra.com/tech_specs/ETQuickRef.html
im just going to try and get a test run off before they find out [&:]
take easy on your runs and try to run 11.5+ and on your last run, cool engine pretty good, then heat the tires, drive it like stolen.. and see what she will run at the best. then you can tell them, no need, i am leaving anyway
