Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
another question for LSX guys
Old Dec 5, 2006 | 02:17 PM
Morbid Intentions's Avatar
Morbid Intentions
Wash Rinse Repeat
Default another question for LSX guys
if I were to get a LS2 C6 about how much RWHP would I gain with these mods (I just need an estimate... nothing fancy or mindraking)
1. full exhaust with LT's, X pipe and catback
2. 90/90 intake and TB
3. 125 wet shot with a clean dyno tune
not familiar with the engine so I don't know the gains from bolt on's [&:]
Old Dec 5, 2006 | 02:33 PM
MrRogers's Avatar
MrRogers
Default RE: another question for LSX guys
ORIGINAL: Morbid Intentions
Lets see... LS2 puts out about 340rwhp+ full exhaust with LT's, X pipe and catback= 370rwhp+90/90 intake and TB=380rwhp+125 wet shot with a clean dyno tune..I would say you should end up with no less than 535rwhp. You will have a beast on your hands. I wouldn't race you thats for sure LOL
Old Dec 5, 2006 | 04:10 PM
V6yellowStang's Avatar
V6yellowStang
ORIGINAL: MrRogers
TB & 90/90 intakes 10RWHP numbers, is that mainly TB or is the 90/90 good for something on the LS2. I know it's good for something, but doesn't the stock intake efficient upto 500Hp(guesstimate) or so? I almost questioned your numbers there Mr. Rogers, but quickly realized I couldnt add this morning, lol. While we are at it...What will a full exhuast (LT, O/R X-pipe, B&B Bullets quad tip) system get my LS6??
Old Dec 5, 2006 | 04:30 PM
stanger88's Avatar
stanger88
I ♥ Acer
1. full exhaust with LT's, X pipe and catback untuned, 365whp, my friend had EXACTLY THIS (except im hazy on if he went X or H, shouldnt matter) and thats what he made on his baseline un-tuned before his cam swap. Oh, with a K&N filter he made 345whp (06 M6 GTO) tuned he probably would have hit 375-380 with the full exhaust.
2. 90/90 intake and TB (thats worth 10-20 togather)
3. 125 wet shot with a clean dyno tune (around 120-130whp or so)
Total rwhp would be around 450-550 on the spray, more accurately probably 500+-25.
Old Dec 5, 2006 | 04:32 PM
MrRogers's Avatar
MrRogers
ORIGINAL: V6yellowStang
ORIGINAL: MrRogers
Well the LS6 is better than the LS2 in my opinon. It also puts down more power to the rear wheels.(Mainly due to the C6s torque management) LTs, X-pipe and some B&B bullets will complement your aftermarket intake. You should expect around 380+ if you get another tune after you install the headers, X pipe and B&Bs. But you need to realize that your Z06 will be extremely loud with this combination! B&B bullets is pretty much like running straight pipes. They don't have mufflers, and then combine that with LTs and your begging for tickets. I also expect some drone from this setup as well. I hope you have an aftermarket sound system or your exhaust will be your radio.
Old Dec 5, 2006 | 04:35 PM
stanger88's Avatar
stanger88
I ♥ Acer
^+1
My friend had LT's, no cats, and a Corsa and it was too damn loud on his GTO after his cam swap, before it was borderline, after the cam...obnoxious.
Old Dec 5, 2006 | 10:24 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
The 90/90 set up won't get you much unless you increase the CI or put on a set of aftermarket higher flowing heads.
Old Dec 5, 2006 | 10:28 PM
98LS1's Avatar
98LS1
ORIGINAL: JD1969
At least on LS1's.....probably holds true for the LS2/6's as well. But alas, it is the best setup possible.
Old Dec 5, 2006 | 10:34 PM
Sleeper05's Avatar
Sleeper05
you would have enough power to do a burnout, we can all agree on that
Old Dec 5, 2006 | 10:47 PM
JD1969's Avatar
JD1969
ORIGINAL: 98LS1
ORIGINAL: JD1969
Yea the LS6/LS2 intake is fine and not a restriction untill you start going to a bigger cam and/or heads.
