Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
G-Tech @ The Track
Old Dec 7, 2006 | 03:37 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Default G-Tech @ The Track
All I ever hear is about how crappy and un-reliable those things are, and I do believe it.
But I was wondering if anyone has ever used one while at the track, to see just how far they
really are off of true times?
Anyone?
Old Dec 7, 2006 | 05:28 PM
98LS1's Avatar
98LS1
Default RE: G-Tech @ The Track
Nope. Can't help ya.
I did use one once and I ran a mid 13 second pass @ 138mph...or something rediculous along those lines.
Honestly, I'd like to see some results from this as well.
Old Dec 7, 2006 | 05:32 PM
92hatchLX's Avatar
92hatchLX
I've heard people using them on the street and then comparing it to their actual times at the track and it was only a tenth off. Other people don't have so good of luck. I think your suspension set up depends on how well it reads. I think it's more accurate with a stiffer suspension, someone explained it to me and I can't really remember.
Old Dec 7, 2006 | 05:47 PM
stanger88's Avatar
stanger88
I ♥ Acer
My friend ran his at the track and after doing the calculations they supply with the instructions to counter-act the lift of the car when on the throttle his was almost spot on.
Old Dec 7, 2006 | 05:54 PM
MustangMagic's Avatar
MustangMagic
I ♥ Acer
ORIGINAL: 92hatchLX
I have a GTech. There are 3 gyros or something called acromoms? Anyway these gyros are built in the unit to compensate for dips and slops in the road when making a run. But they say if the road is flat and you drive straight, your time will be accurate to within a tenth of a second give or take. I used to run consistant 11:30's. That is when I had a built automatic in my 02. All I had to do was get on the converter to 2600 or 2700 rpm and floor it. Now that I converted over to a stick, my times jump all around with a best of 12:72.
Old Dec 7, 2006 | 05:59 PM
92hatchLX's Avatar
92hatchLX
ORIGINAL: MustangMagic
ORIGINAL: 92hatchLX
Were you running a transbrake or were you using like a 3500+ rpm stall?
Old Dec 7, 2006 | 06:13 PM
Demon 340's Avatar
Demon 340
Administrator
ORIGINAL: 92hatchLX
ORIGINAL: 92hatchLX
hold on, she will have to call the shop and ask...
i have used a Gtech, and i didnt find it to be very accurate..i found it to be wrong on the fast side of things.
janine, racing on the track is very different than racing on the street...someday youll learn.
Old Dec 7, 2006 | 06:16 PM
92hatchLX's Avatar
92hatchLX
Oops, I didn't know that MustangMagic used to be Janine. I should've never asked.
Old Dec 7, 2006 | 06:17 PM
Demon 340's Avatar
Demon 340
Administrator
ORIGINAL: 92hatchLX
i laughed out loud at that one...thanks..
oh, and problem solved.
Old Dec 7, 2006 | 06:34 PM
Dingo0079's Avatar
Dingo0079
I have a friend who has one the top of line the, uses it at bithlo all the time is always within .01 of the tracks numbers That is pretty friggin accurate if you ask me it is pricey though.
