Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
warming tires
Old Jan 14, 2007 | 12:42 PM
slySTANGguy's Avatar
slySTANGguy
Default warming tires
I just got an 07 mustang and putting on a pair of drag radials for the track. when i do the burn out i dont want to just do a burn out, i want to do a powerstand. Where the front brakes lock up and the back end can only go left and right but the car never moves, but how do i hit the brakes right to do that with a 5 speed manual?
Old Jan 14, 2007 | 12:47 PM
tehzack's Avatar
tehzack
Default RE: warming tires
I always just rev it up to about 3k or so dump the clutch and grab the brake with my left foot. You can modulate the brakes to hold it still and keep the motor from bogging down. Its not terribly difficult. Some people with snow skis for feet can hold the brake and the gas with one foot.
Old Jan 14, 2007 | 01:05 PM
CobraSnake's Avatar
CobraSnake
^^^^just like he said but, what I do is I go around the waterbox then back in. Then I do a 2nd gear burnout, throw it in 2nd rev it up and dump the clutch, in the water it will be easy to spin in this gear plus you can really warm them up. Alright so 2nd gear dump the clutch and just catch the brake with the left foot. Then when you think you are warmed up enough keep on the gas and let off the brake. You'll still be spinning for a second then once you catch let off the gas or you will have to back up to line up at the tree.
Old Jan 14, 2007 | 01:50 PM
Quick Shot xMLx's Avatar
Quick Shot xMLx
ORIGINAL: tehzack
Tried this once. It's possible but it's a bit more difficult to modelate the throttle. Big foot FTW
CobraSnake why do you put it in second? What's wrong with first?
Old Jan 14, 2007 | 02:17 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
2nd gear will spin the tires faster and put more heat into them.
Old Jan 14, 2007 | 02:21 PM
Quick Shot xMLx
ORIGINAL: JD1969
Damn you learn something new everyday. How about 3rd since more is better
Old Jan 14, 2007 | 07:08 PM
CobraSnake's Avatar
CobraSnake
ORIGINAL: Quick Shot xMLx
ORIGINAL: JD1969
I was thinking about doing a 3rd gear burnout in the new cobra because of the 4.30 gears but, i believe 2nd gear is more then enough.
Old Jan 14, 2007 | 07:18 PM
Apoptosis's Avatar
Apoptosis
poptart tits
ORIGINAL: JD1969
I have never heard about that.. Cool.
Wouldn't some line-locks be right up his aly?
Old Jan 14, 2007 | 08:12 PM
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
second gear burnouts rule. instant smoke, more heat, more spinnage.
on a mustang GT with my mods, would it be wise to do a 2nd gear burnout on the stock clutch?
Old Jan 14, 2007 | 11:58 PM
CobraSnake's Avatar
CobraSnake
ORIGINAL: AmericanMuscle4.6GT
sure why not. It can't be as bad and dumping the clucth in 1st on the street which i know some if not most people do in there stangs which some are stock. I haven't heard of any problems from that so 2nd wouldn't be any different. Plus the water will help the tires brake loose so that should be less strain on the clutch.
