Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
so....
Old Jan 18, 2007 | 02:45 PM
idcoocheimonster's Avatar
idcoocheimonster
Default so....
Ok, now i know there is an endless amout of threads about this, but i just have to ask. Stock, i ran a 14.4 @ 97 mph with a 2.2 60'... So with my current mods, (listed in sig) What do you guys think i will run?
Old Jan 18, 2007 | 03:57 PM
Quick Shot xMLx's Avatar
Quick Shot xMLx
Default RE: so....
You have like nothing honestly. With the same exact driving skill probably a 14.2x. Now since the Tri-Ax helps and you probably gained a lot more experience you "could" run a 13.9 with a good 60.' Well these cars "can" do that stock anyway.
Old Jan 18, 2007 | 03:58 PM
JT76's Avatar
JT76
Default RE: so....
You should be Mid 13's if you can get traction, thats the key
Old Jan 18, 2007 | 04:05 PM
JT76's Avatar
JT76
Default RE: so....
ORIGINAL: Quick Shot xMLx
the X pipe, catback, tune, will help him out.....traction = mid 13's, no traction = more 14 second crapola
Old Jan 18, 2007 | 04:10 PM
Quick Shot xMLx
Default RE: so....
ORIGINAL: stanggang1892
I know it helps but it doesn't really "help." Don't want to get his hopes too high just to be dissapointed...
Always best to have low expectations so when you exceed them you feel good about yourself[8D]
Old Jan 18, 2007 | 08:31 PM
limer06stang's Avatar
limer06stang
Default RE: so....
i would definitly recommend some rear-gears for your next mod!!! 3.90s or 4.10s will work wonders for yah....but i think about a 13.99-14.019 is what i'll guess....i'm VMP tuned also
Old Jan 18, 2007 | 09:20 PM
ant02gt's Avatar
ant02gt
Default RE: so....
14.1ish is my guess
Old Jan 18, 2007 | 10:23 PM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: so....
If all you ran was a 14.7 stock, unless you got a driver mod you'll keep running mid 14's until you get some gears and full bolt-ons. Sorry but 99-04 GT's are not forgiving to mediocre drivers. [&:]
Old Jan 19, 2007 | 04:43 PM
idcoocheimonster
Default RE: so....
Ill be doing BFG DR's (315/35/17) on a 10.5 in. Bullit withing the next 2-3 weeks. And i ran a 14.4 stock not a 14.7. I've seen cars with my same mods run mid 13 range. I'm hoping to be able to cut 1.8ish 60's.
Old Jan 21, 2007 | 05:15 AM
CarlessAndy's Avatar
CarlessAndy
Default RE: so....
Suspension mods would be good too. Things like upper and lower ca's and such.
