Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
brake-torque problems.
Old Mar 12, 2007 | 01:06 PM
bbbaycuuu's Avatar
bbbaycuuu
Default brake-torque problems.
Okay so i got the basics of brake torque-ing down, hold the hell outta the brake, pop into neutral and rev past 3.5k, the brake sinks, put into D and start revving....but my tires still spin even when im holding the brake. and when i pop off i just spin like hell...i have the stock good year eagles but i think i should still atleast be able to launch. Any tips/help you guys could give me? thanks.
Old Mar 12, 2007 | 01:09 PM
Morbid Intentions's Avatar
Morbid Intentions
Wash Rinse Repeat
Default RE: brake-torque problems.
http://www.specriteconverters.com/pro_series.asp
and...
http://www.bfgoodrichtires.com/bfg/productIdSubmit.do
and 3.73 - 4.10gearing with a good tune..... that will get you hoppin off real quick without too much spinning and creeping
Old Mar 12, 2007 | 02:26 PM
Simon1's Avatar
Simon1
You're revving too high. I'm not exactly sure what your stock stall speed is but it's not 3,500. It is usually around 1,800-2000 rpms. Put it in gear, step on brake, give gas and watch the tach. To launch, you will want to hold the rpms just below the rpm your tires start spinning. So if you start spinning at 2000, hold at 1800 or so. You will have to experiment
A smooth launch will get you better results than mashing the gas. The gears on your car are probably a 2.82 gearing. I used to have a 01 GT and Ford switched them under warrunty for free to 3.31 (lowest they would let me go for free). Big difference in acceleration, no gas mileage loss. I would get some 3.73's, that would make you happy. Cost you less than $600 for gears and install. Get a programmer and a stall converter with a higher RPM stall speed and you will be taking time off you 1/4.
With a programmer my car would chirp 2nd,3rd gears.
Old Mar 12, 2007 | 02:52 PM
Demon 340's Avatar
Demon 340
Administrator
is he talking about neutral slamming it?
Old Mar 12, 2007 | 04:32 PM
contentsunderpressur's Avatar
I think he's putting it in neutral and reving it so the brake will go down farther. Then he lets it idle down and puts it back into drive. You don't have to do that. Just hold the brake down and give it a little gas. If it starts spinning let off the gas some until it stops spinning. Let off the brake and stomp it at the same time and you'll go.
Old Mar 12, 2007 | 07:00 PM
tehzack's Avatar
tehzack
I hope he's not out there doing neutral drops. Lol.
Old Mar 12, 2007 | 07:42 PM
98LS1's Avatar
98LS1
ORIGINAL: Ride Of The Month
That was my first thought....just do like my buddy did with his TH350. Get going backwards down a decent size hill in neutral, then drop it in low and nail it! BROKENSTUFFFORTHEWIN!
Old Mar 12, 2007 | 07:47 PM
ThisBlood147's Avatar
ThisBlood147
[sm=lol.gif]
Old Mar 13, 2007 | 01:43 AM
bbbaycuuu's Avatar
bbbaycuuu
yeah i rev to 3.5k for the brake to sink, the problem is when i start revving even when the brake is held the wheels still spin if im over 1.5k. idk whether my brake pads suck or what. and if i cant launch over 1.5k, wats the point of even launching? (and for those wondering, yes im buying a stick car in may lol)
CS2007
Jun 25, 2019 09:45 PM
zanemoseley
Sep 6, 2015 12:58 PM
movielover40
Aug 27, 2015 03:26 PM
DrunknRuckus
Aug 23, 2015 10:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
