Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
8.74 run..
Old Apr 7, 2007 | 05:47 AM
Quicktime_GT's Avatar
Quicktime_GT
Default 8.74 run..
Well.. I just bought a pair of 26x11.50 16 MT ET Streets. I tried um out at the local 1/8th mile.. not as good as what I was expecting but.. either way..
Here are some video's :
http://vids.myspace.com/index.cfm?fu...oid=2018873636
http://vids.myspace.com/index.cfm?fu...oid=2019231598
Notice how the car kinda bounces out of the hole a couple times... whats up with that? I have bbk springs and factory shocks
Any tips or advice would be appreciated
Old Apr 7, 2007 | 05:52 AM
SilvrStang's Avatar
SilvrStang
Default RE: 8.74 run..
Your 60 is really bad. Looks like the tires didnt even hook well.Try staling it about 1800 RPM then launch
Old Apr 7, 2007 | 06:05 AM
Quicktime_GT
Well I actually was running 16 lb of air in them. I was leaving at about 3200 er so I had a tuner issue that wouldn't let my 2 step rev limit go over 3500.
I was running 16 lb of air just because I was nervous.. first time out on slicks. I didn't know how they was going to act so I thought I had rather them spin a little than leave parts out on the track.
We were planning on going back tomar but the weather is crappy so don't guess we will.
This next time I plan to heat the tires up more, lower the psi. in the tires, and leave at about 4-5000 rpms and hope for the best
Old Apr 7, 2007 | 06:12 AM
SilvrStang's Avatar
SilvrStang
As much as I know about slicks,They will hook their best on 12-14 PSI hot
Old Apr 7, 2007 | 02:30 PM
The stang II's Avatar
The stang II
ORIGINAL: SilvrStang
So a 1.8 60 ft time is bad?
Old Apr 7, 2007 | 02:48 PM
CobraSnake's Avatar
CobraSnake
ORIGINAL: The stang II
thats what I was going to say. a 1.8 60ft is definately not really bad.
Old Apr 7, 2007 | 05:43 PM
SilvrStang's Avatar
SilvrStang
I was thinking he was the stang in the left lane,sorry
Old Apr 7, 2007 | 05:52 PM
ZW99GT's Avatar
ZW99GT
One of those cars sounded mean as hell. Did the other car have cams?
1.83 is a good 60ft. Going too much under that is just asking for trouble IMO. Those are good times none the less.
Old Apr 7, 2007 | 06:45 PM
2000GT4.6's Avatar
2000GT4.6
Hold on a sec, your on slicks or the ET street drag radials?
If they are the drag radials they can definatly go faster but a 1.8 isn't that bad with a 3500 RPM launch.
If you go out and do a 5000 RPM clutch dump with even ET streets heated properly on a good track... your 60' time is probably going to be infinite, as your going to break the spider gear.
BUPBUPBUPBUPBUP(2step imitation) POP!
Old Apr 8, 2007 | 03:47 AM
Quicktime_GT
ORIGINAL: 2000GT4.6
haha... they are the straight up old school ET Streets 26x11.50s on a 16 inch wheel. thats why I'm kind of taking it easy untilll I get some axles
