i need a few tips
im going to the track tomorow night and i want to run a 13.0 i know i can do it, i just need some practice..any tips? i have drag radials but im only pullin a 2.0 60ft...i think if i get my 60 down to a 1.9 i should b somewhere arouund a 13.1 or so....HELP?
Your sig says you have adjustable shocks/struts...what do you set them at when you race? Maybe others can chime in and tell you what settings work best...
Also, do you remove the spare and all that other stuff?
i dont know what there set at....when i got them put it the guy set it at what he thought would work the best at the track and no i dont take out the spare...does that make much of a differance?
Since you are so close to your target time, you should take every advantage you can get. You may also want to remove your passenger side headlight for better airflow to your air intake. Check your tire pressure on your front tires, you may want to pump them up a bit (not sure if that is safe or not).
Lower the tire pressure
Like someone said above... remove all the extra weight you can.. I have never removed the headlight, but I guess it might help somewhat?
Back seat, spare+jack, ect... hell if you really want to reach your time you could take out the passenger seat, but IMO its a waste of time.
Do all that, lower you tire pressure and pull a 1.8 60' and say hello to 12's
autoedit
Sep 27, 2015 06:37 PM
Sep 10, 2015 08:39 PM
