Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Highest downshift speeds for maximum acceleration
Old Dec 16, 2004 | 01:19 PM
Etanimulc's Avatar
Etanimulc
Default Highest downshift speeds for maximum acceleration
Whats the highest speed one can downshift in to make their car accelerate as hard as it can? For example: coasting in 5th gear at 60mph, and then going into 3rd to get to 90mph as fast as possible. Can one do this at 90 mph to get to 120 mph, etc.
Old Dec 16, 2004 | 01:43 PM
SilverGTV8's Avatar
SilverGTV8
Default RE: Highest downshift speeds for maximum acceleration
Well you need to be carful because if you say down shift from into to low a gear you will bang the limiter.
PLUS you need to match the revs to the new gear or the car will jerk and you will slow down and look like a goof. If you need to down shift like that you need to learn to heel toe to match the engine revs for the new gear.
Old Dec 17, 2004 | 03:26 AM
89LXcoupe's Avatar
89LXcoupe
Just try at different speeds dropping it into a gear for a sec to see what it brings the RPM's up to. Jut dont drop to a gear and bring yourself above the power band.
Old Dec 17, 2004 | 03:57 AM
Jugador's Avatar
Jugador
or just see what speed each gear tops at and then if youre within like 5 or 10 mph of the end of that gear, you might now wanna drop to it. and give it gas right as you pull off the clutch or just ****in romp that *** and dump it from redline and youll have no problem with slowing down on the downshift.
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
69Volunteer
Sep 30, 2015 10:39 AM
