Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Camaro vs Mustang in the twisties?
Old Jan 7, 2005 | 12:23 AM
DeViouS's Avatar
DeViouS
Default Camaro vs Mustang in the twisties?
Do u guys think the 02 camaro z28 could out perform a 02 Stang GT in the twisties w/ cornering etc.? My brother thinks that the z28 is better in the twisties cuz of weight balancing.
Old Jan 7, 2005 | 12:25 AM
OUZBnd's Avatar
OUZBnd
Default RE: Camaro vs Mustang in the twisties?
i would like to think not
Old Jan 7, 2005 | 12:26 AM
UT04GT's Avatar
UT04GT
I was under the impression the camaro and mustang have the same weight distribution. That and they both have a solid rear axle. Also the f-bodies are longer and heavier than the 99+ mustang GT. Not to mention the added torque of the LS1 would hurt twisty performance. I'd guess it would be really close but the mustang GT would edge a z28
Old Jan 7, 2005 | 01:21 AM
Guest
Guest
Posts: n/a
ORIGINAL: UT04GT
Extra torque will hurt cornering? uh... the extra torque would help get the car through the exits faster if the driver knows how to take advantage of it.
IMO it'll ALL depends on the driver more so than the car itself.
Old Jan 7, 2005 | 01:25 AM
UT04GT's Avatar
UT04GT
ORIGINAL: 2000Si
ORIGINAL: UT04GT
340+ torque on street tires while rounding a corner would HELP? Even with my mustang pushing the gas around a hard turn will put me sideways in a hurry,I can't imagine a solid rear axle car with more torque being able to handle well around turns
edit -> before I get called out, note the STREET tires designation, thanks
Old Jan 7, 2005 | 01:42 AM
Guest
Guest
Posts: n/a
You're not putting the pedal to the metal on a road course all the time, it's not 1320 dragging... As you approach the corner you'll want to be on the outside of the apex on your brakes to get down to the proper entry speed, as you go into the corner you want to go from the outside to the inside lightly applying the throttle, get yourself in a nice smooth curve lightly feathering the throttle, as you apex stay on the gas lightly and as you exit you straighten out and mash the gas in the straightaway.
Like I said it ALL depends on the driver, not the car he's driving.
Old Jan 7, 2005 | 01:43 AM
Guest
Guest
Posts: n/a
for your edit: Street tires or not, torque will help you if you know how to use it.
Old Jan 7, 2005 | 03:21 AM
DeViouS's Avatar
DeViouS
driven by the same driver (obvious not @ the same time). say w/ stock tires. which car will be able to corner easier and quicker?
Old Jan 7, 2005 | 01:05 PM
Guest
Guest
Posts: n/a
the way they sit, I'd say he'd be able to get the Maro through the corners faster. Jut depends on how well he takes advantage of the torque and if he knows how to counter body roll.
Put and 03 Cobra vs an 02 SS and the Cobra will take the SS.
Old Jan 7, 2005 | 01:21 PM
UT04GT's Avatar
UT04GT
put a 390+ HP IRS car against a 320 HP solid rear axle car in a real course and it would be a slaughter
