Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Track tire question????
Old Jul 5, 2007 | 06:33 PM
ZW99GT's Avatar
ZW99GT
Default Track tire question????
I have a set of 275/40/17's MT ET Street Radials on 17x8 wheels. I have had them at the track, and really just havent had any luck at all out of them. Tried every air pressure from 12-22, and I just cant get them to stick off the line. I usually give them an aggressive 2nd gear burnout BTW. Even on motor they wont stick. Yea, I can get a 1.85 60ft, but thats almost getting LITERALLY SIDEWAYZ. When spraying, they just go up in smoke in 1st, and leave me just sitting there.
I just picked up a set of 255/50/16 BFG radials for CHEAP. They have more tread than the MT's but thats not much. I have them on some 05 Sixxer stockers. They OBVIOUSLY have LOTS more sidewall than the MT.
The BFG's are a little taller than the MT's so they may help out on the launch. They are close to the same width.
SO, I really can't make up my mind which ones I want to take to the track. Which do you think would work better?
Old Jul 5, 2007 | 06:37 PM
fazm's Avatar
fazm
Default RE: Track tire question????
if you really want off the line stick, ur going to have to get some ET streets, not ET street radials. mine would spin through 3rd (same size 275/40/17) and once i put the biasply's on, all traction issues were relieved.
oh and between the two, u will probably have better luck with the 16s, since more sidewall.
Old Jul 5, 2007 | 06:40 PM
bluebeastsrt's Avatar
bluebeastsrt
I'd go with the BFG's. A tall sidewall combined with low air pressure should give you more wrinkle and more traction.
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: fazm
I pull 1.5's on my M/T radials and have seen them go high 1.3's. I think he is asking alot of 275/40/17 trying to launch on spray. I think it may have more to do with his IRS than anything else.
Old Jul 5, 2007 | 06:48 PM
ZW99GT's Avatar
ZW99GT
ORIGINAL: JD1969
ORIGINAL: fazm
I'm tired of pulling the "IRS" card out everytime my car launches like ***. lol. But you might as well be 100% right.
I'm just gonna try the 16in BFG's, and if that dont work, 26x9x16 full slicks will be in the works
Old Jul 5, 2007 | 09:55 PM
TommyV8's Avatar
TommyV8
I've seen cars pull wheelstands on ET street radials. My buddy was launching his Camaro on the bottle to 1.5 60 ft times and eventually snapped his rear end. 255/50/16. No suspension work at all.
Old Jul 6, 2007 | 02:37 AM
ZW99GT's Avatar
ZW99GT
Not to discredit your story in any way, b/c that is freaking AWESOME, but that must have been a hell of a nice track.
I go on ricer night, and I'm usually one of the only ones that run slicks, so no one cares about track prep.
Old Jul 6, 2007 | 02:43 AM
fazm's Avatar
fazm
yes, to get the radials to hook, u need incredible track prep. try launchin a 500hp car on drag radials on an unprepped track, and its over. at least with the biasply's u can stand a better chance.
Old Jul 6, 2007 | 03:06 AM
ZW99GT's Avatar
ZW99GT
ORIGINAL: fazm
Lol, I DO! It's impossible, and greatly disappointing when you look at the damn time slip and you can't run what you should b/c of that 1.9 60ft staring you in the face. [:'(] lol
Old Jul 6, 2007 | 03:20 AM
fazm's Avatar
fazm
i took mine to a 2.7 60' the first time to the track with the et street radials.
ended up aborting the run, 13.4 @ 88mph
