Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
fox vs altima
Old Aug 6, 2007 | 05:59 PM
jakeachy's Avatar
jakeachy
Default fox vs altima
89 5.0 convertible with FIPK, flowmasters and magna straights..
against a "stock" 2.5L altima with a siht can.
he wants a dig, and i have AOD with 2.73s
im almost positive i can take him by 2-3 lengths, but there is big stakes so just wanted input..
Old Aug 6, 2007 | 06:11 PM
simpsonfan13's Avatar
simpsonfan13
ELEKTRO-FIDE Moderator
From: In Geo-synchronous orbit over redass' bathroom,
Default RE: fox vs altima
youll own him.....
but if you defenatly wana make sure up the stakes to cover a nos system and get 50 shot
or 3.73's
Old Aug 6, 2007 | 06:12 PM
92lxsleeper's Avatar
92lxsleeper
no don't do it. i had the same mistake a while back in my buddy's 5.0 put atleast a chip in it first, or 3.73 gears then you can take himby 5-10 lengths
jakeachy's Avatar
jakeachy
this race is this weekend, and no money at 16 for mods now.
i am auto.
if i get him.... i get a garret T45 turbo!
his car is a 4dr stick.
Old Aug 6, 2007 | 06:15 PM
simpsonfan13
and if you loose what do you give up?
Old Aug 6, 2007 | 06:31 PM
jakeachy's Avatar
jakeachy
ORIGINAL: simpsonfan13
ive got a set of enkeis
Old Aug 6, 2007 | 07:40 PM
06musgt's Avatar
06musgt
what year altima.the newer ones are pretty quick.
Old Aug 6, 2007 | 08:27 PM
corners's Avatar
corners
Dude, this race will be close. You will lose big time out of the hole, but you will run him down. My predictions are:
<1/8 mile = you lose
1/4 mile = close (you have a slight edge)
>1/4 mile = you win.
Oh, and those are for the 2.5L Altima. The 3.5L will own you.
Here's a couple tips. Do NOT race him with your top down. The top down creates so much more drag and makes a HUGE difference. I speak from personal experience.
FYI, I used to own a 1989 5.0 convertible. With underdrive pullies, and a K&N drop in, I ran a 16.1 1/4 mile at 90 mph. The stock 2.73's suck major ***. It was the slowest car I've ever owned off the line.
Old Aug 6, 2007 | 09:36 PM
fiad06's Avatar
fiad06
You will rape his ***....my sis has a 2.5s and it is slow as *****....it has 180hp and 180 tq....and it probably weighs more than you....you will kill him
Old Aug 6, 2007 | 10:54 PM
94Blk5.0's Avatar
94Blk5.0
1. Practice your launch. Find your RPM to break stand.
2. Over inflate the front tire a little maybe 38-40PSI, proper pressure in the back.
3. Get a fresh fuel filter, $10, use sand paper to clean the contact points on the rotor and the inside of the cap.
4. Top up(like he said), windows up, air off.
5. Before hand, determine the length, the longer the better.
6. Put the trans in overdrive and leave it, no manuel shifting.
7. Maybe remove sparetire/jack ,and anything else loose.
8. Run some fuel system cleaner through your next tank of gas.
9. Clean T.B, and make sure the MAF wire is clean.
That all the cheap/free things I can think off right now. I think that the race is yours if you can launch well and keep it wound up.
Jan 21, 2016 01:30 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
Glocker23
Sep 23, 2015 08:19 AM
