Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Just got drag radials, looking for opinions/experiences
Old Aug 22, 2007 | 08:18 AM
Grabber's Avatar
Grabber
Default RE: Just got drag radials, looking for opinions/experiences
+1. You should get at least a 1.8-1.9 60'.You do have to heat the living crap out of them to really get a good use of them.
Old Aug 22, 2007 | 08:31 AM
S8ER01Z's Avatar
S8ER01Z
ORIGINAL: TommyV8
^I'll be there!
Tommy if I had thought about it...I was just in St Loius last weekend! DOH!!
Old Aug 22, 2007 | 08:35 PM
xxkazp3rxx's Avatar
xxkazp3rxx
I did a 4k dump... bogged and put down a mid 1.8 60"... Speaking of which, I need to get some news ones... the steel belt is showing in the middle [:@]
Old Aug 22, 2007 | 09:18 PM
eindow's Avatar
eindow
What's the specs on the tires??? width/height/diameter???
The best I've cut on 275/40/17 Nitto's are high 1.6's and consistant 1.7's in the black Cobra.
On the crappy 2.73's and stock converter you shouldn't be cutting anything better 1.96's without spray... Just my .02 Tommy
Old Aug 22, 2007 | 10:20 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
You SHOULD cut a lot of time off your 60', unless you're like me and your best 60' to date is 2.02 on a set of MT's
Old Aug 22, 2007 | 11:19 PM
nickdotcom2.0's Avatar
nickdotcom2.0
i did not like the nittos that much so i switched the the MT ET street radials.
i think the problem was that i didn't heat them up enough. since them i've heard 10 seconds or more is needed.
but they would always start spinning at the same RPM, with the mickeys i have noticed that once they get to that rpm they push me forward wether i want them to or not.
Old Aug 23, 2007 | 06:40 AM
02StangGuy's Avatar
02StangGuy
i have the nittos on my regular rims then a set of mickeys on my prostars....obviously the mickeys hook better but the nittos are fine also...i pull 1.9 60fts on them and for some reason have run better times with them then my mickeys! i have herd different things about the nittos tho...some people have told me to run a high psi in them but i have always found that 17psi and heating them up good works for me. good luck with them...break into the 12s!
Old Aug 23, 2007 | 06:48 AM
xxkazp3rxx's Avatar
xxkazp3rxx
i dunno.. I just smoked em until i could see it off of my tires... then just went up to the line with around 17psi in my tires and they were fine...
Old Aug 24, 2007 | 01:51 PM
eindow's Avatar
eindow
Start off at 17psi and drop it as the day progresses to where you feel it hooks best, I've found they hook best between 10-12psi..
Old Aug 24, 2007 | 03:23 PM
92hatchLX's Avatar
92hatchLX
Mine kick ***! The 555r's are really a great street strip tire. I drop my tire pressure to about 12 and launch it and they hook great. Are gears and a Yank stall in your near future? That thing will haul ***
