Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
new best untuned
Old Nov 10, 2007 | 07:35 PM
rsw007's Avatar
rsw007
Default new best untuned
installed iron gt40 heads,ported stock lower and 1.7 rockers. still on the 125 wet shot and drag radials. shifting at 5200rpms witch may be too low.
1.43 60ft
7.07@95mph
11.23@117mph
i need to get it tuned and install the 150 jets and try for a 10.99
Old Nov 11, 2007 | 12:54 AM
MustangMadness7's Avatar
MustangMadness7
Default RE: new best untuned
With a tune and slightly higher shot you will definintely break 10's. Nice numbers
Old Nov 11, 2007 | 01:16 AM
1BAD3V's Avatar
1BAD3V
Nice numbers all around, but a very nice 60' time.
Old Nov 11, 2007 | 06:39 AM
rsw007's Avatar
rsw007
thanks guys it has always been a good 60ft car. just doesnt pull strong up top with the lockup converter.
Old Nov 11, 2007 | 06:53 AM
bluebeastsrt's Avatar
bluebeastsrt
Thats a heck of a 60FT.
Old Nov 11, 2007 | 07:22 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: rsw007
1.43 60ft
7.07@95mph
11.23@117mph
Scott, your short time makes me ill, lol. How do you pull that off? Congrats on the new best!! I run the same mph but .8 tenths slower and it's pissing me off. [:@]My best 60' is a 1.7, I know that has a lot to do w/ it.
Old Nov 11, 2007 | 09:15 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: PRO50SC
ORIGINAL: rsw007
1.43 60ft
7.07@95mph
11.23@117mph
Ahhhh the beauty of nitrous and a big converter. Centrifical blowers don't have the torque hit down low that spray has.
Old Nov 11, 2007 | 03:46 PM
rsw007's Avatar
rsw007
looks like i picked up 2mph n/a and 5mph on the 125shot. it definatelly felt stronger on the top end.
Old Nov 12, 2007 | 11:34 AM
rsw007's Avatar
rsw007
pro heres the suspension list agian
suspension
1. 4.10 gears
2. moroso front drag springs with 2 coils cut out, monroe struts for 4cyl., upr c/c plates
3. steeda lower control arms, upr adj. uppers, lowering springs with 1/2 coil cut out.
4. sub frame conn. and driveshaft loop.
5. welded boxes
6. air bags in rear 5lbs driver 12lbs passenger side
7.aluminum driveshaft
Old Nov 12, 2007 | 11:54 AM
drhoward's Avatar
drhoward
Penis Mod Erator
what kind of cam are you using, with my tfs1 cam and ported gt40p's with 1.7's my car was pulling right up to 6000rpm's (untuned as well)
