Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
decreasing AOD foxbody 60'
Old Nov 11, 2007 | 09:14 PM
Epic91GT's Avatar
Epic91GT
Default decreasing AOD foxbody 60'
the past times at the track my 60' was 2.33 and 2.23 what are some simple things i can do to lower my 60' by next weds
Old Nov 11, 2007 | 11:29 PM
Sarge_13's Avatar
Sarge_13
Default RE: decreasing AOD foxbody 60'
Since I don't know what you have done to your car already, I'd say some suspension stuff; LCA's and UCA's and either DR's or slicks.
Old Nov 11, 2007 | 11:47 PM
Epic91GT's Avatar
Epic91GT
the car is stock, the only thing i do when i go to the track is lower my tire pressure to 23 PSI . is that the only thing i can without spending a nickle haha i like see what the car has without adding to it
Old Nov 12, 2007 | 12:17 AM
Morbid Intentions's Avatar
Morbid Intentions
Wash Rinse Repeat
lower control arms are alot more important than upper control arm's... at least at the track..... and also just from what I heard
so I would say a set of LCA's and a set of DR's would get you rolling for under 500 bucks
Old Nov 12, 2007 | 01:21 AM
Ahnial8u's Avatar
Ahnial8u
I would invest in some gears and a Converter with that on street tires you should have no problem hitting 2.0 60'.
Old Nov 12, 2007 | 05:19 AM
rsw007's Avatar
rsw007
is it spinning? if not add gears and converter.
if it is then just practice and get control arms.
practice is free.
Old Nov 12, 2007 | 09:39 AM
Epic91GT's Avatar
Epic91GT
nah im not spinning and once i get some money i am doing gears i just dont know which ones im getting yet. i was just seeing if there is anything i could do to get my time down by weds
Old Nov 12, 2007 | 09:51 AM
drhoward's Avatar
drhoward
Penis Mod Erator
gears aren't going to help your 60' any on street tires....they will probably hurt you[8D]
Old Nov 12, 2007 | 01:06 PM
Epic91GT's Avatar
Epic91GT
i was just trying to do little tweaks with the car as it is now to better my 60'
Old Nov 12, 2007 | 01:27 PM
rsw007's Avatar
rsw007
bump timing and check tps voltage.
when i had the stock converter i got better times when i spun the tires just 2-3ft. it helped the car get up the rpms.
