Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
0-60' times
Old Nov 15, 2007 | 11:23 PM
94RedDevil's Avatar
94RedDevil
Default 0-60' times
What is a good 0-60' time for my car.
Trick flow top end
24 lb. injectors
TF stg. 1 cam
70 mm tb
80 mm maf
dont know what else you need to know about motor
Suspension:
KYB adj. shocks/struts
Eibach sportline springs
Energy suspension spring isolators
I know i need more suspension work but what are good 0-60's for my mods?
Old Nov 16, 2007 | 04:27 AM
Sleeper05's Avatar
Sleeper05
Default RE: 0-60' times
60', or 0-60?
60': anywhere from 1.5-2.0 depending on tires, suspension you don't mention, track prep, and a number of other factors.
0-60: I would imagine that a 4.6-4.8s time would be about right if you are running 13.4 at 105.
Old Nov 16, 2007 | 07:53 AM
94RedDevil's Avatar
94RedDevil
Does 1.5-2.0 sound right to everyone? I'm trying to figure out what i should be shooting for
Old Nov 16, 2007 | 08:32 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
DO you mean 60 foot? If so a 1.7-1.8 is pretty good. You not going to see 1.5's without more power.
Old Nov 16, 2007 | 12:49 PM
johnnyv8's Avatar
johnnyv8
Are you on street, dr, or slick tires? Im on street and my best is about 2.flat, i know a couple of people hitting 1.9's. But im guessing w/ ur trapt spds, ur on street tires...im guessing, so if thats the case. i would think 2.0 is good, anything below is great.
Old Nov 16, 2007 | 05:31 PM
97tplsGT's Avatar
97tplsGT
anythings better than my [:'(]consistent[:'(] 2.4s-2.5s[:@] [:'(] If you're a decent driver with decent tires....1.9-2.1 dr's...........1.7-1.8's like previously stated, anything lower is gonna be hard to come bywithout anymore power
Old Nov 17, 2007 | 12:17 AM
94RedDevil's Avatar
94RedDevil
ok, thanks a lot guys. yes, i am on street tires. i'm working on getting upper and lower control arms this weekend then i'm either going to go with a tubular k, a-arms and coil overs. or if thats out of my budget i might just go with some nice dr's
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
