Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
how the HELL...
Old Dec 12, 2007 | 07:13 PM
  #21
Sleeper05's Avatar
Sleeper05
Default RE: how the HELL...
...The launch...
Old Dec 12, 2007 | 08:15 PM
  #22
ripped camel's Avatar
ripped camel
It's all about mastering the take off!
Old Dec 12, 2007 | 09:19 PM
  #23
I G Joe's Avatar
I G Joe
ORIGINAL: Ride Of The Month
have you ever driven a high stall auto car with some power?
two of our faster LS1 owners here both swapped from a manual to an auto, and ran better times, if im not mistaken.
doesnt make you a good driver... just makes the odds of you getting a consistent time higher and takes the odds against you having a consistent lauch away. Automatics are easier to drive IMO making you less of a driver. a manual does require more skill but most people driving a stick suck at it.
Old Dec 12, 2007 | 09:20 PM
  #24
craz1469's Avatar
craz1469
My 86 Monte Carlo had a stalled th350 with a manual valve body and a b&m pro stick. It is a 1000 times easier than the camaro. The only way to mess up driving is to shove it from 1st to 3rd which is hard to do with that shifter. Just roll into the throttle on the street. At the track its boring to drive, after going into 3rd I start looking around it ran 12.20s. Now the camaro is a lot different, bringing the rpms up at the line to 6-6,200 dump the clutch and start banging the gears.Which is harder now than ever because of my stock clutch and hydraulics. It doesn't like shifting in to 3rd and forget about 4th.
Old Dec 12, 2007 | 10:27 PM
  #25
avexhype's Avatar
avexhype
Hmmm interesting reponses. Well i was really talking about the street not pro drag racing or race purpose built automatic cars. Alot of people in the first couple of responses were getting a bit too technical.Im talking simple runs on the street.I still think its VERY hard to mess up an auto on a race at the most you just have to know how to play the throttle which shouldnt be hard at all and if someone cant figure it out they shouldnt be racing in the first place.
As the owner of an automatic with quite a bit of drag racing experience, I will say that it takes no skill at all to drive. Press the right foot down and hold it there, that is all.
Mine is a garden variety stock-stalled auto. -Tommy v8
+1. I used to take out my moms 3.5 altima (auto) and the only skill it required for racing was flooring it, sitting comfortably back in the leather seats, and holding the wheel.
Old Dec 12, 2007 | 10:45 PM
  #26
empatho's Avatar
empatho
well with my z28 I cant just floor it because Im just going to stay there burning rubberand from I roll I pick the speed so I dont hit that 4l60e dead spot [:'(]
Old Dec 12, 2007 | 10:52 PM
  #27
ripped camel
ORIGINAL: avexhype
Again dude it's all in the take off. The take off is no different at the track, than it is on the street. He whom has the best take off, gets out of the hole the best.
I would level many cars for half the race, that should've absolutely decimated me. The reason is because I had near perfect R/T times, so by the time they started moving, I was already gone!
Master the take off and the only thing that holds you back at that point is the car!
Old Dec 12, 2007 | 10:56 PM
  #28
avexhype's Avatar
avexhype
Ok ill give you that. But compare an auto vs a stick from a dig. Your not going to tell me the auto is NOT a **** load easier to launch AND can be consistent almost every single time, unlike a manual were you might 1.rev too low and take off slow 2.might bog the **** out of the launch 3.rev too high and spin or even (i hope not) 4.have uber l337 newb skillz and stall it on take off.
Old Dec 12, 2007 | 10:59 PM
  #29
ripped camel
ORIGINAL: avexhype
Depends on the driver. I found that I can launch a stick better. You can control letting off the clutch as opposed to the brake with an auto. I think a stick is much easier for the experienced driver!
Old Dec 12, 2007 | 11:22 PM
  #30
avexhype's Avatar
avexhype
Oh ok man lol, yea true.But man... i still cant see how some people see auto is harder! [:@]heh, well if u can feather the clutch on a manny, you have to control BOTH the gas and clutch to not mess up your launch. On the auto u just let off the brake and IF u have to then just feather the gas pedal only. eh, whatever[8D]
