Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
'00ish WS6 vs. My S197
Old Jan 29, 2008 | 03:25 PM
  #21
JT76's Avatar
JT76
Default RE: '00ish WS6 vs. My S197
no comment [8D]
Old Jan 29, 2008 | 07:50 PM
  #22
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: Stone629
I just don't see a beating like you guys are saying. The op has alot of mods to to get those 4.10s to the ground. We all know he has a 13.0 car with just the Tune and intake. Add up the rest of his mods and I say he is moving out pretty good, especially from a dig. Stall or not, I say the OP will take him off the line. Unless they are racing past a full 1/4 mile, it's going to be closer than you guys think. This is just my opinion and in no way am I saying the WS6 is not a fast caror will lose, I just think it'll be a good, close race. Stalls are pointless without DRs,so all that mod is going to do is cause the T/A to spin his *** off and lose, if he tries to use it.
I agree about the DR's, but if the WS6 has them (and it's just dumb for it not to) the Stang is toast. Why do I say this? Because I know first hand what a bolt on/stalled LS1 wil do. The Stang in question is not a low 12 car, the WS6 is (with traction of course)
Old Jan 29, 2008 | 08:16 PM
  #23
bluebeastsrt's Avatar
bluebeastsrt
ORIGINAL: iluvmycar
Fast and The Furious?
What the hell is wrong with you?
LOLOLOLOL
Old Jan 29, 2008 | 09:28 PM
  #24
TommyV8's Avatar
TommyV8
Who puts a stall in their car and doesn't put any type of sticky tire on it?[&:]That is really counterproductive. I have a stock stall (and gears) and I still need drag radialsto keep from screeching loudly and slowly from the line.
Old Jan 29, 2008 | 09:43 PM
  #25
tripsevn7's Avatar
tripsevn7
Moderating with Angels
it should be a good race with the determining factor being the launch on the street. I do see the fbody ahead by a car and a half.
Old Jan 29, 2008 | 09:47 PM
  #26
Stone629's Avatar
Stone629
ORIGINAL: JD1969
ORIGINAL: Stone629
I'm in agreement with you on the DRs. Trust me, like you, I've been there too. Stalled LS1 with no Drags had me in the mid-upper 12s knowing that tires would have got me a low-low 12.The OP didn't mention tires as a mod for this particular stalled WS6, which is the only reason I'm thinking he (the WS6) may have a tough time launching that thing compared to the OP's set-up. I'm going to put my $$ on the Stang out-launching him and the T/A catching him down the road.
Old Jan 29, 2008 | 09:54 PM
  #27
Stone629's Avatar
Stone629
ORIGINAL: TommyV8
Hahaha....I'm guilty. I was scaredof tiresbecause of the GM rear. I built mine twice without DRs. I still got a 1.75 60' due to the suspension stuff, but honestly the DRshad me a little nervous on the 7.5".
Old Jan 29, 2008 | 09:58 PM
  #28
TommyV8's Avatar
TommyV8
Oftentimes tires are not listed in mod lists because the mods that arelisted would seem to suggest that sticky tires are just a given. No one is going to install gears, a stall, engine work, etc. and then put Sumitomos on the back wheels.
BTW with my gear ratio I don't think I could break my rear diff on the motor even if I tried via a stall, stickier tiresand suspension work. Even on the bottle I think it could hold up, especially if I installed a TA cover with the preload bolts. I've seen 3.23 rears hold up to many 1.5 60 ft launches courtesy of a stall and a bottle.
Old Jan 29, 2008 | 10:23 PM
  #29
Stone629's Avatar
Stone629
Yea, but I have shatty luck[8D]
Seriously, I was having some bearing issues, etc. I never actually broke/cracked anything or chipped gears. I too have seen some serious 60' times on the stock rear, but the amount of problems I was having with the trans (replaced twice) and the rear diff stuff, I was just trying to play it safe.
I know what your saying though, and agree. They can hold up,Iwas just getting a little paranoid with the troubles I was having.
Old Jan 30, 2008 | 02:43 AM
  #30
MrRogers's Avatar
MrRogers
I think the Fbody will win. Years agoI ran across a stalled/minor bolt onLS1 camaroin my C5 Z06 at a light..I was thinkin.."time to smoke another catfish" boy was I wrong...F***er got out the whole like a bat out of hell and just keep pullin.[&:]
