dyno's vary, do 1/4mile tracks?
i know elevation will cause variation in times at tracks but can different equipment? or perhaps if a track isn't 100% level (uphill/downhill). and if so, is that common?
i guess the reason i'm curious is because i'll randomly see 1/4mile times that seem a bit low. like the '08 350z running 13.1x and folks running 13.2-3 in the s197 stock. could some of that be due to a generous track?
random question i know but i've seen way dumber topics than this.
late
late
If a track is NHRA or IHRA sanctioned, it is tested to be within a tolorance of being level. The biggest factor is, of course, elevation, but surface prep will have a large effect on 60 foot, and thus 1/4 mile time.
Elevation can have a significant effect on ET. Track prep makes a big difference, both in 60' times and down track, as poorly prepped tracks may result in wheelspin while shifting into 2nd, 3rd etc, where it wouldn't happen on a well prepped track.
ORIGINAL: JD1969
For instance, I race here in Germany at a small airport that sets up 1/4 mile runs every month or so during the summer. The DA is usually around 1800', and they do ZERO track prep at the location due to environmental reasons.
The result is some pretty terrible times overall for everyone.
ORIGINAL: 67mustang302
elevation is the biggest thing that I have seen
I mean I hang around in here enough to know what most cars "should" run, typically at the track in Calgary, you can add a second on to that and it will get you in the ball park
Some tracks have inaccurate measurements and timing equipment. For example, the now defunct Mid America Raceway in Missouri had a 60 ft that was actually only 54 ft; a lot of dumbasses would talk about how much better they hooked there.[sm=smiley36.gif]Also, if the concession stands were busy and therefore sucking up a lot of power, the timing equipment would slow down and make it look like a car was faster than it really was. Most major sanctioned tracks have equipment that prevents this, along with accurate measurments. Needless to say, timeslips fromMAR were pretty much useless.
