Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Can't stop fishtailing!
Old Mar 7, 2008 | 05:42 PM
Mustang 03 GT's Avatar
Mustang 03 GT
Default Can't stop fishtailing!
The age old saying is true: If you're spinning, you ain't winning. I've tried launching from 2500 to 3000 and my car is still fishtailing. I also tried to launch from 2nd and it still fishtails. Do you guys have any input or suggestions? I would appreciate it. (Racing the 94 Z Sunday). One last thing is fishtailing a word?
Old Mar 7, 2008 | 05:44 PM
Demon 340's Avatar
Demon 340
Administrator
Default RE: Can't stop fishtailing!
i see mods, and a manual transmission...and no mention of tires...
Old Mar 7, 2008 | 05:48 PM
Mustang 03 GT
Stock tires stock rims.
Old Mar 7, 2008 | 05:50 PM
Stone629's Avatar
Stone629
Stop dumping the clutch. Roll off it. If that doesn't work, take off normal and then roll into the throttle.
Old Mar 7, 2008 | 06:05 PM
Mustang 03 GT
Finally some help! Thanks man I appreciate the input.
Old Mar 7, 2008 | 06:15 PM
Gene K's Avatar
Gene K
How far are you slipping the clutch. You cant just "Drop" it. You have to slip it out.
Try bringing it to around 3000 rpm and then slipping the clutch out while slowly rolling into the throttle.
You can adjust rpm, and how aggressive you are with the clutch and throttle from their.
Demon 340's Avatar
Demon 340
Administrator
ORIGINAL: Mustang 03 GT
while stones advice is good, if you want to get the most out of your car, you need tires that can put the power to the ground.
Old Mar 7, 2008 | 06:29 PM
AZ SNAKE's Avatar
AZ SNAKE
Get some Drag Radials, HPM mega bite jr LCA and adjustable upper, and slip the clutch
Old Mar 7, 2008 | 06:41 PM
Mustang 03 GT
I am about to buy some 18 inch rims soon what kind of tires should I buy?
Old Mar 7, 2008 | 06:42 PM
Gene K's Avatar
Gene K
The kind that fit on 15's.
