Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
changing tires
Old Mar 22, 2008 | 04:19 PM
graygt07's Avatar
graygt07
Default changing tires
i will be taking a pair of m/t tires to the track this year and i need help with changing them. can i jack the rearend up on the differential and change them both at the same time? the owners manual said not to do it that way. i thought i read on here that someone has done it. i have ground effects and i was hoping to make things easy. thanks
Old Mar 22, 2008 | 04:27 PM
Stkjock's Avatar
Stkjock
Retired Mod
Default RE: changing tires
Ford says not too. but most guys do. in fact yesterday my speed shop jacked from there when they need to get under the car to make adjustments
Old Mar 22, 2008 | 04:32 PM
Subotai_95's Avatar
Subotai_95
ORIGINAL: Stkjock
Meeehhh.. it's POSSIBLE, but you really shouldn't.. I've seen guys both destory differentials, and punch holes in gas tanks/trunks by doing that if/when the thing slips off the jack.. If you're using the factory jack that came with the car, there are indentations on all four corners of the frame that were intended to be used as jack points..
If you're using a different type of jack you could use the differential, but I'd be careful broham..
Old Mar 22, 2008 | 04:49 PM
graygt07's Avatar
graygt07
i have a 3 ton floor jack that i will be using. I was planning to chalk the front wheels. i want to be able to change them both at the same time if possible.
Old Mar 22, 2008 | 05:53 PM
bluebeastsrt's Avatar
bluebeastsrt
Well as long as your aware theres a possibility that you could flex yourdiff. housingand your willing to take that chance your golden.
2007StangV6
Jan 28, 2016 06:09 PM
2007CalSpec
Sep 9, 2015 05:37 PM
M3hunter
Sep 5, 2015 03:42 PM
