Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Matching revs
Old Apr 13, 2005 | 09:12 AM
Etanimulc's Avatar
Etanimulc
Default Matching revs
How does one match revs?
Old Apr 13, 2005 | 10:58 AM
BCisme's Avatar
BCisme
Default RE: Matching revs
match revs with what?
Old Apr 13, 2005 | 11:17 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Engine and tranny is what he is referring to I believe. The only time they are not matched is when you press in the clutch while still rolling. So all it takes is pratice. If you're going from fifth to third just rev the engine above the rpms you left off in and slowly release the clutch. Thats about the best I can explain. I can do it perfectly but putting it into words is a little harder. Its just a matter of knowing all the rpms at every speed (usually measured in 10's) in every gear.
Old Apr 13, 2005 | 12:10 PM
dc_mann8's Avatar
dc_mann8
if your in 5th going 50mpg revving 2000 rpm, and you want to shift to 3rd and you are going to be revving say 4000 in 3rd if you were to do that, then when u push the clutch it to shift, rev up to 4000 before letting the clutch out into 3rd
correct? i think im right but maybe not
Old Apr 13, 2005 | 06:28 PM
iwrxit's Avatar
iwrxit
that is the simplest way to explain it. you dont have to exactly match, but the r you get, the better. it allows for smooth transfer of power and keeps the tires flom locking up.
Nick Oliver
Oct 17, 2018 04:22 AM
firehorse02
Nov 16, 2015 11:28 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
wraith777
Sep 28, 2015 10:49 AM
Offendant
Sep 23, 2015 07:21 PM
