HOW TO LAUNCH?!
Mach I Section Moderator
ok since this question comes up so often here my buddy suggested that we do the video on the track, so we did, and here it is!
http://videos.streetfire.net/video/How-to-Launch_156629.htm
*edit*
i only used the clutch in 1st, thats why its so jerky
**edit 2**
THESE ARE STREET TIRES SPECS ARE AS FOLLOWS
245/15
400 tread wear
39-40psi
*edit*
**edit 2**
245/15
400 tread wear
39-40psi
ORIGINAL: Quick Shot xMLx
Such a good launch all you hear is tire spin through first. That was kind of FTL. Try slipping it more.
BTW it was 74* here today, and the track temp was about 80-85.
ORIGINAL: fazm
what you mean you only used the clutch in 1st gear? you slammin the gears without the clutch?
good way to destroy your transmission. its not meant to do that, and you will see negligable gains in the 1320'
i pulled a 1.9 on 255 bfg street tires with 44psi in them
did a 1.9 on my 295 nitto's as well with 44psi in them, but that was a lot easier lol (only tried twice)
ORIGINAL: fazm
, the next run was my 8.84 run, on a 2.09...... im thinking about driving north to get colder temps at the track, its already getting to hot here...and the track is losing a lot of its grip. i couldnt get in my right lane due to the "professionals" getting lane choice.i tell you what, if any of ya'll think you can pull a sub 2.0 in MY weather on my tires in my car you can come try, but im gonna be willing to bet you can't. BTW the humidity was @80% SEE
