Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Not getting traction
Old Apr 25, 2008 | 01:13 PM
Magic_Man's Avatar
Magic_Man
Default Not getting traction
I'll list my setup 1st:
Drag springs
Non-Adj drag shocks up front
10 way Adj Strange shocks in rear
UPR rear upper & lower control arms
no front sway
3.73 gears
26"x11.5" ET Street radial slicks
2500 stall
C4
I've adjusted the shocks from soft to stiff & nothing seems to change much. I've had the slicks at 18-14.5 psi and just about the same results. I've launched off the converter & off idle. Can't get traction either way.
I have made passes on motor & on spray. The juice is setup on a WOT switch. The run that I went WOT right off the bat I got a 1.8 60'. That is the best 60' I have been able to get w/this car so far. Only two 1.8s. The rest have been from 1.9 to 2.1.
I know the gears don't help traction, but the car, not w/me driving, has cut much better 60's.
Should I try running less air in the tires? If so, how low should I go?
Old Apr 25, 2008 | 01:16 PM
Sarge_13's Avatar
Sarge_13
Default RE: Not getting traction
Are you heating them properly?
Old Apr 25, 2008 | 01:26 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
What is the pinion angle? Try 15 psi in the slicks and work down in 2 psi incriments (stay abouve 12 is the rims are not screwed and you your not running tubes). Is the car actually spinning? With 1.9-2.0 and only a 1.8 on the can it does not sound to me like the car is spinning, but I would want to know either way.
Old Apr 25, 2008 | 01:46 PM
Magic_Man's Avatar
Magic_Man
ORIGINAL: Sarge_13
I do long burnouts
Old Apr 25, 2008 | 01:48 PM
Magic_Man's Avatar
Magic_Man
ORIGINAL: JD1969
I don't know.
I have tried 15 & best 60' was 1.9.
The car was obviously spinning on some. It didn't feel like it spun on the 1.8 run, but I didn't have anyone there with me to tell me for sure.
Old Apr 25, 2008 | 02:39 PM
JD1969's Avatar
JD1969
How are you launching? and were other cars having issues as well or was it just you. With slicks a 2.0 is either REALLY bad spin or a bog. 2500 is a pretty low stall so that's not really helping you, unless you are spraying it out of the hole.
Old Apr 25, 2008 | 02:41 PM
Magic_Man's Avatar
Magic_Man
ORIGINAL: JD1969
I was going off idle. There was a 5 speed fox on juice on ET drags cutting 1.6s.
I sprayed out of the hole on the 1.8 run off idle.
ChampInSD
Oct 2, 2015 04:55 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sep 8, 2015 11:50 AM
iculookin
Sep 2, 2015 12:34 PM
ccwebb
Aug 11, 2015 06:47 PM
