Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
GT500 traction problems.
Old May 10, 2008 | 06:32 AM
08 Bullitt 2310's Avatar
08 Bullitt 2310
Default GT500 traction problems.
I'm having some severe wheelspin at the top of first gear a boost hits max and that's taking off from a roll.It seems to be fair on the street until this point.Any advice on getting Eagle F1's to hook.It might be better at the track,Might be worse.Any advice other than new tires would be helpful.
Old May 10, 2008 | 06:36 AM
1BAD3V's Avatar
1BAD3V
Default RE: GT500 traction problems.
You've got alot of power under the hood man, not sure if those tires would be that great. Are you just easing into the throttle or trying to gun it? Are those F1's the stock tires on the GT500?
Old May 10, 2008 | 06:44 AM
Morbid Intentions's Avatar
Morbid Intentions
Wash Rinse Repeat
trying to putthat much power and torqueto the ground with stock F1'sduring WOT at such low speedsis like trying to deliver a baby with razor wire... it just isn't going to work.
try DR's or less throttle... more weight in the back could help, like sandbags and such, that will give you weight above the rear tires and they should be less prone to slipping when it's warm out.... which is another factor you should pay attention to... make sure it's a summer temperature out, flooring itat 40-60 degrees is just asking for slippage at any speeds in 1st gear
Old May 10, 2008 | 07:02 AM
1BAD3V's Avatar
1BAD3V
ORIGINAL: Morbid Intentions
You ever have trouble with traction during normal driving?
Old May 10, 2008 | 07:11 AM
Morbid Intentions
Wash Rinse Repeat
yeah, even with torque management in full effect... if I turn TC off and it's even a little cold out, going into second will send me sideways... I have it down to a science where if it's over 70 degrees I will just bark second and hit it with no problems... anything under that and it's up in the air
I never floor my car during first gear speeds unless I'm going from a stop.... when that automatic finds 1st from a low rollit hits hard and sends the car all over the place
just wait till I get a tune and null down the torque management [&:]
Old May 10, 2008 | 09:28 AM
IWHINE's Avatar
IWHINE
Can you limit boost via the ecm/pcm? thats what i do in first to help a little bit with tire spin and it makes the car drive much smoother.
Old May 10, 2008 | 11:57 AM
BicketyBam's Avatar
BicketyBam
Is there a reason why don't want to put a proper sized tire on the car? By all accounts, the stock tires are way too narrow.
Old May 10, 2008 | 03:31 PM
Sarge_13's Avatar
Sarge_13
ORIGINAL: BicketyBam
Amen. The GT500 needs at least 295's out back.
Some LCA/UCA's couldn't hurt either.
Old May 10, 2008 | 05:09 PM
BicketyBam's Avatar
BicketyBam
When I get a GT500, I will have new tires, UCA/LCA's within the first week. Plus I plan on doing gears, so it's pretty much a must.
Old May 10, 2008 | 05:52 PM
SubTexel's Avatar
SubTexel
ORIGINAL: 1BAD3V
Yeah the F1s come stock on the GT500s. I know when my buddy got his GT500 he was all shocked my car came with F1s stock like his GT500 had. I don't have trouble hooking up with F1s, though I only have 410rwhp and 415rwtq on an IRS car. lol.
