WS-6 vert
My brother-in-law's brother (I can explain some other time) showed up this weekend with a black 2000 Ram Air vert. He let me take it for a ride and I thought it would be a low 13 to high 12 car. The car has some sort of chip in it and that was all. What are these cars supposed to run? I'm going to take him to a track in the next few weeks and see exactly what it will do.
Got this from sight called maximum.
ear:
2001
Make:
Pontiac
Model:
Trans Am WS6
Base Price:
$27,590
Origin:
Romulus, MI, St. Catharines, ON
¼ mile:
13.9 Seconds
0 - 60 MPH:
5.5 Seconds
Gas Mileage:
City: 19 MPG / Hwy: 28 MPG
Position:
Front Engine
Configuration:
LS1 V8
Valvetrain:
OHV
Displacement:
346 CI / 5671 CC
Power:
325 BHP / 242.4 KW @ 5200 RPM
Torque:
350 FT LBS / 474 NM @ 4000 RPM
Redline:
6000
Bore:
3.90 IN 99 MM
Stroke:
3.62 IN 92 MM
HP/L:
57.01 BHP per Liter
HP/LB:
10.5 LBS per BHP
Compression:
10.0:1
Block:
Cast Aluminum
Cylinder Head:
Cast Aluminum
Ignition:
Coil-near-plug
Fuel Delivery:
Sequential-port fuel injection
Induction:
Ram Air
Firing Order:
1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Fuel:
91 octane recommended
Drive Wheels:
RWD
Curb Weight:
3417 LBS 1549.7 KG
Weight Dist:
56 / 44
Length:
193.7 IN / 4919 MM
Width:
74.4 IN / 1890 MM
Height:
51.8 IN / 1316 MM
Wheelbase:
101.1 IN / 2568 MM
Front Track:
60.7 IN / 1542 MM
Rear Track:
60.6 IN / 1539 MM
Ground Clearance:
4.5 IN / 114 MM
Steering:
Power, rack and pinion
Steering Ratio:
14.4:1
Turning Circle:
40.1 FT / 12.2 M
Materials:
Full unitized steel
Front Brakes:
Vented Discs
Front Brake Size:
11.9 IN / 302 MM
Rear Brakes:
Vented Discs
Rear Brake Size:
12.0 IN / 305 MM
Front Tires:
P275/40ZR-17
Rear Tires:
P275/40ZR-17
Front Suspension:
SLA/coil over monotube gas-charged shocks, tubular stabilizer bar with links 30 mm stabilizer bar
Rear Suspension:
Salisbury axle with torque arm, trailing arm, track bar, coil springs 19 mm stabilizer bar
Transmission:
6-Speed Manual
1st Gear Ratio:
2.66:1
2nd Gear Ratio:
1.78:1
3rd Gear Ratio:
1.30:1
4th Gear Ratio:
1.00:1
5th Gear Ratio:
0.74:1
6th Gear Ratio:
0.50:1
Reverse Ratio:
2.90:1
Final Drive Ratio:
3.42:1Another sight called Modern racer says they'll do the quarter in a tick over 13 flat I thought the convertible would be alot heavier but both sights say it weighs in around 3417. So I'm going to split the difference and say it'll run a 13.5
ear:
2001
Make:
Pontiac
Model:
Trans Am WS6
Base Price:
$27,590
Origin:
¼ mile:
13.9 Seconds
0 - 60 MPH:
5.5 Seconds
Gas Mileage:
Position:
Front Engine
Configuration:
LS1 V8
Valvetrain:
OHV
Displacement:
346 CI / 5671 CC
Power:
Torque:
Redline:
6000
Bore:
3.90 IN 99 MM
Stroke:
3.62 IN 92 MM
HP/L:
57.01 BHP per Liter
HP/LB:
10.5 LBS per BHP
Compression:
10.0:1
Block:
Cast Aluminum
Cylinder Head:
Cast Aluminum
Ignition:
Coil-near-plug
Fuel Delivery:
Induction:
Ram Air
Firing Order:
Fuel:
Drive Wheels:
RWD
Curb Weight:
3417 LBS 1549.7 KG
Weight Dist:
56 / 44
Length:
193.7 IN / 4919 MM
Width:
74.4 IN / 1890 MM
Height:
51.8 IN / 1316 MM
Wheelbase:
101.1 IN / 2568 MM
Front Track:
60.7 IN / 1542 MM
Rear Track:
60.6 IN / 1539 MM
Ground Clearance:
4.5 IN / 114 MM
Steering:
Steering Ratio:
14.4:1
Turning Circle:
40.1 FT / 12.2 M
Materials:
Full unitized steel
Front Brakes:
Vented Discs
Front Brake Size:
11.9 IN / 302 MM
Rear Brakes:
Vented Discs
Rear Brake Size:
12.0 IN / 305 MM
Front Tires:
P275/40ZR-17
Rear Tires:
P275/40ZR-17
Front Suspension:
Rear Suspension:
Transmission:
6-Speed Manual
1st Gear Ratio:
2.66:1
2nd Gear Ratio:
1.78:1
3rd Gear Ratio:
1.30:1
4th Gear Ratio:
1.00:1
5th Gear Ratio:
0.74:1
6th Gear Ratio:
0.50:1
Reverse Ratio:
2.90:1
Final Drive Ratio:
the vert will go a little slower due to the weight, but those performance specs have been so misquoted....
all ls1's make 350hp from the factory floor. the ratings were so bogus
also, the chip thing irks me something fierce. people use it to sell cars but it is physically impossible to chip and ls1, and the "chips" for the lt1s except for the 93 are these shady *** inline modules rather than a real chip. there is no removable map containing chip on the 4th gen fbody pcm. its probably stock as a rock.... Ive had dealers tell me before on an lt1 "yeah, and this baby has a special chip that gives it 400 horses. she really moves!"
I turned around without a word and just left his dumb *** standing there smiling like an idiot.
ORIGINAL: SpecterGT260
Yeah, the chipped thing annoys me as well. About the only thing chipped these days are Diesels, and even then the real stuff is in PCM tuning like EFI Live and the like...
