1/8th mile et?
can you guys give me an estimate on what you think my car will run at the local 1/8th mile
stock bottom end fresh about 650 miles
gt40 iron heads
1.7's
e303 cam
trick flow street intake
24# inj
long tubes
off road x
3.73 gear
k&n filter
pro m 75mm
70mm tb
no smog
stock suspension
stock tires
5 speed car
i also have drag radials but i will not be using them this time but if you would give a time and speed with both i would appreciate it
gt40 iron heads
1.7's
e303 cam
24# inj
long tubes
off road x
3.73 gear
k&n filter
pro m 75mm
70mm tb
no smog
stock suspension
stock tires
5 speed car
first off... I dont know you... so I dont know if you can drive or not... second there are WAY too many variables, to even come CLOSE...
so hows about you just go to the track, and find out
ORIGINAL: 91lx50udlose
9.2?????? that sounds a little slow i got a buddy with a 5.0gt with a cold air intake long tubes off road h pipe and it ran 9.30 with 2.73 gears
I will set a goal for you 91lx. With the same gears, long tubes, meter, e fan, cold air and underdrives. Stock TB, intake, heads and cam.
8.9 @ 80.6 in the eighth.
235 45 17" Dunlop radials.
I feel my car is pretty strong in the 1/8 for a stocker. Hopefully you should match or beat my et but your cam and heads should put you much faster than 80.
well i took it last night to the track i couldnt get off the line for anything but i managed an 8.80 at 87mph the best part about it i pulled my buddies ls1 transam about 3 cars
i know the car has more in it than that but with the 87 mph speed i feel like with some drag radials i could see real low 8's
