Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
how do you stop from rolling at the track?
Old Jun 12, 2008 | 07:17 PM
Epic91GT's Avatar
Epic91GT
Default how do you stop from rolling at the track?
well i never race a 5spd at the track and i dont know if the car will roll while staging. does the car need to b stopped at all from rolling and how would u go about stopping it? ie handbrake or footbrake
Old Jun 12, 2008 | 07:50 PM
darkmach1's Avatar
darkmach1
Default RE: how do you stop from rolling at the track?
are you talking about the burnout? if you are you do a powerbrake( accelerate, than dump clutch fast and step on brake hard) this you should try on an isolated street before embarrasing yourself at the track. If you're talking about staging, you slowly roll forward until BOTH staging lights are on, then brake till a standstill, then accerate with clutch fully pressed then slip out quickly on green(after 3 yellow lights). With time you will start launching at the third yellow instead of green, this will lower your reaction time.
Old Jun 12, 2008 | 07:56 PM
Ryan86272's Avatar
Ryan86272
umm, mine doesnt ROLL when im at the Staging Line, I would imagine Holding the Break Lightly?
Is ur Track on a Hill? THe time doesnt Start untill you Cross the line so u can roll a little bit forward.. Try Deep Staging???
Old Jun 12, 2008 | 09:57 PM
laserredgt's Avatar
laserredgt
feel your clutch..eventually you will find out the sweet spot at where your car starts to move depending on the position of the clutch...once you feel it start moving push it back in just a bit...thats when you accelerate to whatever rpm you feel you dont bog down at. try launching at the 2nd or 3rd yellow depending on how fast you can react...i take off when the 3rd yellow is about to change and i cut 5.1 and 5.0 alot...
Old Jun 12, 2008 | 10:03 PM
ripped camel's Avatar
ripped camel
The car shouldn't roll at all at the staging lane. The track should be level!
Old Jun 12, 2008 | 10:14 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
I've rolled at the staging lines before. Believe me, it's annoying as hell.
I actually have a 30 second time slip that happened because I started rolling, forgot how my clutch worked and killed the car, and as it jolted forward, it crossed the line. lol
can you say embarrassing?
Old Jun 13, 2008 | 06:01 AM
bluebeastsrt's Avatar
bluebeastsrt
If your rolling at the line it might indicate that your clutch is slipping.[:@]
Old Jun 13, 2008 | 06:42 AM
08 Bullitt 2310's Avatar
08 Bullitt 2310
Could be a clutch grabbing issue or a really unlevel track.Try pumping the brakes a time or two before releasing them to get the pads to stick and help with the roll.Or find a level track if at all possible.I've seen some tracks that look unlevel and that really sucks.When i was a kid I went to a track that literally went up a slight grade[:'(]
Old Jun 13, 2008 | 09:45 AM
72MachOne99GT
ORIGINAL: bluebeastsrt
Even if the clutch is fully disengaged, and the shifter is in nuetral? [8D]
Old Jun 13, 2008 | 11:27 AM
okbfd's Avatar
okbfd
Man, rolling would suck. I was lucky that Tulsa is flat. [8D]
