Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
LS3 vette sub 11 second pull
Old Jul 17, 2008 | 05:40 PM
  #31
andrewzpsu's Avatar
andrewzpsu
Default RE: LS3 vette sub 11 second pull
ORIGINAL: C6 VETTE
ORIGINAL: BicketyBam
ORIGINAL: 05MidBlueGT
Stock LS3's are known to go 11's though > Showroom Stock LS3 ran 11.718 @ 119.94 MPH in Englishtown, NJ off of a 1.839 60'
Link> http://www.youtube.com/watch?v=iSsR-B1p_Os
A better way to phrase that would be "A stock LS3 is known to go 11's".
One LS3 car has done it. ONE.
Showroom Stock
11.71 @ 119.94 - AndrewZPSU - 08 M6 - (2590)
12.16 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2744)
12.18 @ 117.72 - Hardhattg - 08 Z51 M6 - (2690)
12.21 @ 115.45 - LS1LT1 - 06 A6 - (1282)
12.23 @ 115.58 - 06C6FVR - 06 Z51 M6 - (337)
12.23 @ 112.86 - 940CACC - 08 Z51 A6 - (2880)
12.31 @ 114.82 - CYA Vett - 05 F55 M6 - (679)
12.35 @ 117.47 - Bain - 08 A6 2.73 npp - (2759)
12.40 @ 114.70 - Jschindler - 08 Z51 M6 NPP - (2138)
12.41 @ 115.38 - HOXXOH - 08 A6 F55 - (2486)
12.42 @ 117.11 - EZ28 - 08 Z51 M6 - (2735)
12.42 @ 113.90 - DrRichie - 05 Z51 M6
12.49 @ 115.54 - 1.8T - 08 Z51 M6 - (2314)
12.49 @ 114.90 - Jschindler - 05 Z51 M6
12.52 @ 114.44 - Pettvette - 08 A6 - (2842)
12.54 @ 114.67 - Proney - 07 M6 - (2886)
12.53 @ 113.00 - Wicked07C6 - 07 Z51 M6 - (918)
12.54 @ 113.59 - Tony 63 Vette - 06 A6 - (1514)
12.54 @ 113.74 - Tony96LT4 - 06 Z51 A6 - (1153)
12.56 @ 113.39 - Red Sleeper - 06 A6
12.56 @ 112.00 - Orange C6 - 05 Z51 A4 - (60)
12.60 @ 114.12 - Beefcake - 08 A6 - (2882)
12.63 @ 114.88 - Prankster - 06 M6 - (1625)
12.65 @ 111.65 - Zippin Zee - 05 Z51 M6 - (51)
12.66 @ 113.61 - CFP40 - 08 A6 2.73 npp - (2834)
12.66 @ 113.03 - Mdrrandall - 07 Z51 M6 - (1679)
12.69 @ 112.32 - Silverlx - 06 A6 - (876)
12.70 @ 112.43 - Jelsis - 06 Z51 A6 - (456)
12.70 @ 113.00 - Blackmajik - 07 A6 - (1631)
12.71 @ 111.30 - Flyin05 - 05 Z51 M6
12.71 @ 111.00 - Demented - 05 Z51 A4
12.72 @ 111.98 - SR0707 - 06 A6
12.74 @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.75 @ 109.25 - Ponchorello - 05 A4 3.15 - (994)
12.76 @ 112.57 - C5Pilot - 07 Z51 A6 - (907)
12.79 @ 112.17 - Jchazr - 05 Z51 M6 - (451)
12.80 @ 111.00 - SheDevilC6 - 07 Z51 A6 - (1672)
That 11.7 "showroom stock" should be taken with a grain of salt...I remember reading that the computer was re-flashed to stock...But you cannot verify if all parameters have been reset...furthermore, hearing a cooling fan stay on for a large part of the staging time as well as having a lap top plugged in means something is "Rotten In Denmark"
As for the video....[sm=bs.gif]
I'm the guy that ran the 11.718, ironically this made it to the GTO forums and I felt compelled to clear stuff up lol
It was reflashed to stock and I did not use the computer to cool down the car, infact I was afraid that people would say stuff that I didn't pull out the computer till after the run.
It was a cold day, I kept the car off as much as possible, and did not have the lap top plugged in until after I ran the 11.7. Basically I started the car right before the staging line to have it as cool as possible. I warmed up those tires very nicely and only had low 20 psi in for pressure since they're runflats. I launched at 3000-3500, somewhere in there, and I shifted hard, you can actually hear me chirp 4th.
The video is real, my girlfriend at the time was recording it.
After running the 11.718 @ 119.mph I tried to put on my tune and have a clean run but I started smoking the clutch, it just dropped to the floor basically. So I had to get off the throttle, pull the clutch off the floor, and then get back on it. Even with getting off the gas and back on, I stillran 11.8 at over 120 mph. The clutch problem happened again and I wasn't allowed any more runs after that. I'm thinking it would have gone 11.5 if the clutch problem didn't happen.
I verified it twice the all the tables were stock the day before going to englishtown. My goal was to have a comparison between the stock tune and an aftermarket tune, but because of a little too agressive clutch slipping, I never got clear results. I still however believe the higher mph speaks for itself with getting off the gas and back on.
On a side note, It was cold enough that the actual run corrected to an 11.9.
If anyone's got questions I'd be more than willing to answer them if I haven't already done so.
Andrew
Old Jul 17, 2008 | 07:15 PM
  #32
MrRogers's Avatar
MrRogers
Thanks for clearing that up. I remember seeing you catch a lot of heat in CF. You handled yourself well.
Old Jul 17, 2008 | 07:57 PM
  #33
05MidBlueGT's Avatar
05MidBlueGT
See Boys... This guy is for real. Stock LS3 runs in 11's (next to Z06's)...
Any Questions?
Old Jul 17, 2008 | 08:04 PM
  #34
MrRogers's Avatar
MrRogers
Any Questions?
Like I told you before, the LS3 is impressive. But you must realize, the top 3 passes in the LS3 C6 and Z06 are almost a full second apart and nearly 9-10mph on the trap.
Old Jul 17, 2008 | 08:30 PM
  #35
fazm's Avatar
fazm
next to z06s?maybe c5 z06s
Old Jul 17, 2008 | 08:44 PM
  #36
Gene K's Avatar
Gene K
I will take Andrews word for the 11.7 @ 119 in a M6 Z51 3.42 on a negative DA day.
On first blush it looksa little funny but the 12.1 @ 116 car thatsnext on the list is a A62.73 car.
Many of the people on the list dont have the opportunity to run at negative DA with a track well enough prepped to hook in the cool air. Most of them are also not willing to kill the clutch for an 11 second slip in a M6 car.
PS I dont buy the video that started this post either.
Old Jul 17, 2008 | 08:52 PM
  #37
BicketyBam's Avatar
BicketyBam
Any Questions?
No one said he wasn't. Who annointed you LS3 Defender? You don't even own one.
Old Jul 17, 2008 | 10:51 PM
  #38
bluebeastsrt's Avatar
bluebeastsrt
Any Questions?
LOL here we go again.
Old Jul 18, 2008 | 01:04 AM
  #39
andrewzpsu's Avatar
andrewzpsu
ORIGINAL: Gene K
I pulled a low 1.8 60'. I don't have the slip infront of me to tell you exactly what it was, but it definately helped out. When I was pulling 2.0-2.1 I was running 12.1-12.3, and thats when I first got the car and didn't know how to launch it.
I haven't seen anyone else that had my DA pull the same 60's. Which I think makes the difference. If all the times were corrected I think we'd see a lot around the 12.0 range.
Old Jul 18, 2008 | 10:17 AM
  #40
andrewzpsu's Avatar
andrewzpsu
Sorry, I got confused about the videos. My video on youtube of me going 11.7 is obviously real. But the video that started this post definately is not at a track. Its definately fast, but I don't know that we have a 10 second run on our hands until we have a 10 second time slip.
