Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
WTF? My TB/Plenum slowed me down!?
Old Aug 14, 2008 | 06:14 PM
  #31
BolognaPony's Avatar
BolognaPony
if i can cut 1.6 60 foots on the nitrous and 1.7s on motor with slicks then surely this guy can too.
decent to good 60 foots only require a GOOD tire and a lil common sense.
Old Aug 14, 2008 | 06:44 PM
  #32
uenvyboykin's Avatar
uenvyboykin
^+1 I had a set a 16 inch nitto drag radials, couldnt get better than a 1.9 to save my life... ran the car 50 times or so, 1.9-2.09 all day...
swithced to a 15 inch mt et street and probelm solved 1.6-1.8 60' all day
Old Aug 14, 2008 | 10:03 PM
  #33
GStam66's Avatar
GStam66
Originally Posted by bikeboy587
problem solved, drive mod needed, stay in the tempo george where u belong
If i took the tempo to the track, im pretty sure it would last longer than your car would.
I also noticed something last night tho, my friend and i were driving around being stupid and i was driving behind him, i saw him take off, so i floored it, and the car didnt downshift... We were going about 35 or 40 mph. I wanna say that the TPS is off a bit when i installed the new tb and plenum, but the car is idling fine, about 100 rpm below where it used to tho. Think that might have any effect on whats going on now? Sometimes it will downshift, others it wont.
Old Aug 15, 2008 | 07:44 AM
  #34
BolognaPony
If it makes you feel any better Gstam, i run 8.6 @ 78 N/A with slicks so your car definitely has a lot more ET in it with the MPH you have, if you get some decent tires.
the first couple hundred feet are pretty much the most important part of a dig race.
Old Aug 15, 2008 | 09:06 AM
  #35
GStam66's Avatar
GStam66
Yeah but the thing is, i get traction just fine, with 2.0-2.2 60ft's tho. My problem isnt traction, its launching so that i get the most power off the line possible. And since i got the new TB/Plenum, its not going so well. I need to either tweak the tune, or see if my TPS is tweaked cause of my WOT from a roll issue perhaps.
Old Aug 15, 2008 | 09:24 AM
  #36
99GTvert's Avatar
99GTvert
is my username.
Originally Posted by fazm
i cut 1.89 60' n/a with my v6 with only 210rwhp and stock springs/shocks/struts.
dont see why he couldnt with more horsepower and torque.
His stall isn't helping enough here. Is your car a stick or auto?
Old Aug 15, 2008 | 10:02 AM
  #37
GStam66's Avatar
GStam66
Ya would think that stalling at 2500 instead of 1900 would make SOME difference... :\
Old Aug 15, 2008 | 12:58 PM
  #38
JD1969's Avatar
JD1969
Pro. B.S. caller outer
You need to stall that thing up as high as possible. With such a low stall, you are already handicaping yourself, you need to be leaving at as high of an rpm as you can.
Old Aug 15, 2008 | 01:59 PM
  #39
GStam66's Avatar
GStam66
Well the max i can stall at is 2500, but its a 2800 stall. Meaning that with more power and torque, id be able to stall higher. I think the guy at the shop said that 30 more horses or footlbs would let me stall about 100 rpms higher or something. Have to make the motor more powerful so that theres more slip in the converter, hence a higher stall.
Old Aug 15, 2008 | 02:25 PM
  #40
JD1969's Avatar
JD1969
Then stall it to 2500 and see what happens.
