Ok, Should I Even Try This Car From a Dig?
remember a termi weighs a few hundred more pounds.
a gt with slicks, heads/cams, gears, suspension, exhaust could hit mid 12s, but id say high 12s is more realistic.
I still see a low 13 second car. If anyone has this set-up and can post up some slips please post them up. Fazm the OP didn't mention slicks or suspension. I still think it will take more than heads and a cam to run in the 12's. Hell most supercharged GTs with 450+ HP are only running low 12s. Americanspeed is 12 flat right now with a wipple. If you throw slicks and suspension into the equasion. The mid 13 second SRT-4 I mentioned becomes a 12.9 to 13.3 car.
From: Where gunshots are more common than birds chirping
I call BS on the cams on the DOHC. Maybe 96-98 cams in a 99-01 set of heads. HOWEVER, top 12's isn't out of the question with a perfect run. Running the car on the street though, I'd venture to say he's bottom 13's with a 13.0 being a possibility. I went 13.50 with my 2v motor on street tires with cams and bolt-ons.
ive personally seen a gt with a 4.6 DOHC with heads/cams, higher compression with pump gas + torco running 12s n/a. that was on street tires with horrible horrible traction.
his car also put down nearly 360 or 380rwhp, i forget which.
same engine builder that built this 4.6 DOHC (which put over 400rwhp on race gas n/a)
now would i think the guy he is racing has a setup like that? probably not. im just saying its very possible to go mid 12s, without even slicks if you wanted with a 4.6 dohc, it just takes money and a purpose built motor.
We're all aware enough money can make anything fast. Even sad V6 stangs & anemic 4 banger neons.
well the car in the picture doesnt get drag raced lol. its a show car thats trailor'ed everywhere it goes. except he drove it to my shop, which i thought was a gutsy move lol.
the gt however, did drive to the track, and drove home.
but ya, definately doubt the gt he is referring to is anything like those motors.
I guess people do not realize a set of cams for a 4v will still run you upwards of 600 dollars for the bumpsticks only...
FYI, stock Mach/Terminator cams will idle rough and you might think that they're cammed.
Thanks for all the responses.
It seems nobody around town has an answer about this kids car. I know for a fact he changed the heads on a 2V. It's not a motor swap. As for cams, IDK. I've heard it idle and I can't HEAR cams, but you never know.
I did have a chance last night to do a quick burst in 3rd from 50-70mph and it looks like I'll pull him on the top-end. He wouldn't stop to line them up...............
I've just never heard of people doing a head swap on a 2V to a 4V.
