Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Track/gear question.
Old Oct 14, 2008 | 11:30 AM
Mock01's Avatar
Mock01
Default Track/gear question.
As my sig says, I don't have a 4th gear. I'm still wanting to go to the Lapeer track meet this Saturday though, so I have a question for you guys.
The car has 3.73 gears and normally I have to go into 4th for just a little bit. Is there some way to figure out what RPM I would be at in 3rd if I just kept it in there longer than normal? I figure I'd redline, but only very shortly...Does that question even make sense? Lol.
I seem to recall there being a formula or something that you could use, but don't remember anything else...Thanks guys.
Old Oct 14, 2008 | 11:34 AM
99GTvert's Avatar
99GTvert
is my username.
Uhhh
I don't know of one, but I'm sure someone knows. BTW you may want to consider just running the full eighth and then either coasting or going into fifth gear and running some weird *** time.
7STANG's Avatar
7STANG
99GTverts minion
I am not quite sure. Does your tuner let you bump up the redline? Maybe you could bump it up and not have to shift out of third. By the way - I will see you there on Saturday.
Old Oct 14, 2008 | 11:36 AM
Mock01's Avatar
Mock01
I figured if anyone would know, it'd be one of the S/S veterans.
If it was up to me, I'd be there no matter what, even if it was just to run the 1/8th. I just want to figure out if I can do the whole run in 3rd before I talk to my dad about it.
Old Oct 14, 2008 | 02:55 PM
AmericanSpeed's Avatar
AmericanSpeed
There is most definitely a formula, try google. Run some taller tires if you have them, that may be enough to get you through the quarter in 3rd.
Old Oct 14, 2008 | 03:29 PM
Ryan86272's Avatar
Ryan86272
Well in your sig you Trapped 104mph...... Soo go out on a Long HWY Stay in 3rd Gear see what it Redlines at. If its not 104mph, ur going to have to Shift..... or just keep it just Under the redline untill you Pass the 1/4.....
There are plenty of Gear Calculators where you type in:
Car
Tire Size
Gears
Tranny
and it tells yah everything you need to know. Im not sure how accurate they are.
Old Oct 14, 2008 | 03:32 PM
Mock01's Avatar
Mock01
The highest I trapped ever is 106, but same difference. I didn't think about that idea, thanks!
Old Oct 14, 2008 | 03:34 PM
ZW99GT's Avatar
ZW99GT
Do the 01 cobra's have a T3650? What size tires are you running? What's the rev limiter at?
Old Oct 14, 2008 | 03:42 PM
AmericanSpeed
try using this csgnetwork.com/multirpmcalc.html - add the http://www. to the front of the link. The last one on that page will allow you to figure what rpm you are at in 3rd gear. You need to know your gear ratio (3.73) , height of your tires, what mph you will complete the 1/4 at (remember, trap speed on the slip is the average speed for the last 66 ft of the track, so you are passing the line at a faster speed than your trap speed), and the ratio of the gear you will be in when you finish (final gear ratio)- this would be the 3rd gear ratio for you, so you will have to look it up (4th gear = 1.0, 3rd will be some higher number). The MPH might be hard to figure out if you have never gotten a clean run in the quater with 4th gear intact.
Old Oct 14, 2008 | 03:47 PM
AmericanSpeed
That is a quick and easy way to figure it out, but you will need to be able to go a couple of mph faster than 104 in third since trap speed is the average of the last 66 feet of the 1/4 mile, meaning you are passing the finish line at a faster speed than you trap.
