Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Help-suspension setup
Old Dec 5, 2008 | 03:48 PM
2005mach1's Avatar
2005mach1
Default Help-suspension setup
Hello guys,
need help with a strip/street suspension, yes strip first, street second!!!!!!!!!!
car's suspension is all stock now-springs,control arms everything, including wheels and tire(17")
My best 60' is a 1.94 with stock tires and automatic with 2500 stall
I bought race lower control arms and lower control arm relocation brackets.
also bought the rear sway bar relocation kit for 15" wheels
my goal is to get my 60' down to 1.80 with DR's
I plan on some DR's not sure if I'am going 15" or 17" what do you think?
thought I would go 26" tall so I don't need to change my 3.31 gears
I want a 1 pc driveshaft, a upper control arm.
what else do I need? springs, shocks,struts?
Old Dec 5, 2008 | 05:16 PM
modaddict's Avatar
modaddict
Well I hate to break it to you but if you are going for strip first, you really wasted some money there. First off, forget relocating anything in the rear end. Lose the sway bar all together for a BMR extreme anti roll bar and keep your LCA's where they are supposed to be and fit a 15x10 or 15x11 wheel no problem.
After that, switch to QA1 shocks and get some better springs, panhard bar, strengthen up your rear and put some coilovers up front. Get the BMR front swaybar delete/rad support kit and if you've got the cash, then a tubular K member with Tubular a-arms will help a bit too.
Get a 'REAL' converter for your trans with the right stall and be prepared to ditch the 5r55 if you plan on making big power.
Now just make HP and you'll hook it!
Old Dec 6, 2008 | 07:26 PM
2005mach1's Avatar
2005mach1
Thanks
anyone else have any ideas????????????????
Old Dec 7, 2008 | 02:21 PM
Darkcrime's Avatar
Darkcrime
Bill,
Do something to get .1hp, the whole "299.9hp" is KILLING ME!!! hehe.
Our auto's suck without a high stall, best bet I would think is to have lca's, some 15's and nice dr's and hope you hook.
Old Dec 8, 2008 | 03:26 PM
BMRFabricationSales's Avatar
BMRFabricationSales
Former Sponsor
Originally Posted by 2005mach1
Hello guys,
Hello, a good starting point is going to be your lca's both upper and lowers and also a set of relocation brackets. Even if the car isn't lowered you can benefit from the relocation brackets by changing the instant center of your suspension. Going with aftermarket control arms will benefit you by replacing the factory soft rubber bushings with a higher durometer urethane. Of coarse shocks will help anything is better than the factory ones, but if you going for a good handling shock with good street and drag potential the Tokico D soecs are a great choice. They are adjustable and are a good all around shock. If the car see's more drag strip time than anything the QA1'S are the best choice. I will post you a link to our site. We make parts from the front to the rear. If you have any questions please give me a call.
http://www.bmrfabrication.com/2005Mustang.htm
Old Dec 8, 2008 | 04:33 PM
2005mach1's Avatar
2005mach1
Thanks
my relocation brackets are yours!!!!!!
also the lower control are race with soild hiem no bushings
Eveeryone has been telling me to change the panhard bar but I don't see/understand how
this helps 60'???
Old Dec 8, 2008 | 06:04 PM
97tplsGT's Avatar
97tplsGT
Originally Posted by Darkcrime
Bill,
+1, lol. As far as advice, Im useless. Im learning as I read this thread....... Good luck with w/e choices you make.
If you don't know, modaddict should be a credible source for good advice, just look at his accomplishments with his machine.
Old Dec 8, 2008 | 08:25 PM
Stkjock's Avatar
Stkjock
Retired Mod
generally good advice from BMR, they make quality stuff as well.
If you get the relocation brackets make sure they are welded in!
Old Dec 9, 2008 | 10:46 AM
2005mach1's Avatar
2005mach1
Yes i'am welding them in for sure
Old Dec 11, 2008 | 10:56 AM
BMRFabricationSales
Former Sponsor
Thanks
this helps 60'???
If you lower your car then you will need an adjustable panhard bar. It will correct you body alignment with the rearend. When you lower a car the body shifts off to one side, the adjustable panhard bar correct this. As some other have stated our extreme anti roll bar will give you the best 60'times. If you have any questions concerning any of our parts please give me a call.
