Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Track Times
Old Jun 4, 2005 | 02:01 AM
CarlessAndy's Avatar
CarlessAndy
Default Track Times
Went to the track tonight and drove away very dissappointed to say the least. I REALLY need to prectice. I got about 8 or 9 runs, red lighted 2 times because of rolling out of the staging lights backwards [:@] Anyways what i found as a problem is with my gas pedal sticking. When i was staging the throttle started to stick when sitting at idle. I tried to gingerly push the pedal to find it was hard then when i did push it it revved over 2000rpm. This has a lot to due with the times i ran and need to fix it, weather it means putting my stock throttle body back on or whatever i need to do. Anyways enough chatter, on kuhmo estca supras heres my best 2 times.
R/T .827
60 2.357
1/8 9.749 @ 75.69
1/4 14.888 @ 96.47
R/T .864
60 2.359
1/8 9.781 @ 74.67
1/4 14.984 @ 94.84
I had my best reaction time was .452 and then i continued to spin through first so that ended up being a 15.2. My first thing on my list is to figure wtf is going on with the throttle, after that practice, practice and more practice. Tell me what you think good or bad.
Old Jun 4, 2005 | 02:34 AM
dan's Avatar
dan
Default RE: Track Times
was this your first time at the track? If so thats not all that bad.
Old Jun 4, 2005 | 02:49 AM
CarlessAndy
First time with 2wd, took my Audi to the track a couple times last year.
Old Jun 4, 2005 | 03:08 AM
Chris98Formula's Avatar
Chris98Formula
Thats not bad at all for your first time I had a friend that ran an 18.04 in his GT on his first pass. Get you some Nitto dr's and that time will drop alot.
Old Jun 4, 2005 | 11:12 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Good times for the fisrt time out, don't worry about reation time it does not affect the ET, get to know the car and then worry about your RT
Old Jun 4, 2005 | 02:29 PM
98gtmustang's Avatar
98gtmustang
not bad at all, just keep practicin, you'll get those times down in no time!
carid
Jul 8, 2016 09:55 AM
StalkerGT
Sep 25, 2015 02:41 PM
RWHEELS
Sep 5, 2015 03:42 PM
whatsup62
Sep 3, 2015 01:38 PM
Sep 1, 2015 08:16 PM
