Finally got booted from the Track!!!
Went to the track last night, finally had some cool weather, around 58 degrees. I set a new best ET, MPH, and 60' !
Mods: Whipple HO, 10 psi, VMP dynotune, 93 octane, MT ET Streets, rear sway bar, lowering springs, adj LCAs, adj Panhard, panhard brace, tokico D-spec adj shocks & struts, aluminum 1-piece driveshaft, competition stage 5 clutch, lightweight flywheel, STS, K-member brace w/ torque limiters. No weight reduction.
First run of the night, car was still hot with only about 20 minute cool down.
60'=1.617 - new best!
1/8=7.369 @ 95.84
1/4=11.428 @ 120.71
http://www.youtube.com/watch?v=Pt00dpJNBiA
Second Run:
60'=1.676
1/8=7.391 @ 96.82
1/4=11.417 @ 122.08
http://www.youtube.com/watch?v=r1MbAE4449E
I was told after the first run to slow down since I had no roll cage, after the second run I got the boot!! Happiest drive home from the track yet! Probably going out friday night as it is supposed to drop to around 45 degrees.
1/8=7.369 @ 95.84
1/4=11.428 @ 120.71
Second Run:
60'=1.676
1/8=7.391 @ 96.82
1/4=11.417 @ 122.08
They also mentioned that I needed a fire jacket as well. I'm seriously thinking about caging her as I go to the track at least once a week. This is my only car but I rarely drive it as I live in walking distance to pretty much everything I need (work, grocery store, gym, etc) and when I do drive I never use the back seat. I've already been talking to my performance shop guy about the cage last night. If I do the cage, I'm going to add some HP, whether it be from a 12 lb pulley and race tune, or possibly a small shot of nitrous (eventually forged block). If I'm going to have a cage, I better be needing it on every run.
our tracks here not let you run w/o a fire jacket if the car is blown
you can get removable door bars and leave them out but for when you venture to the track
If I could get to the track that often I'd likely cage miine, but I'm lucky if I get there 5x a year
