Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Short (60') Times
Old Feb 10, 2009 | 08:30 PM
gburke1's Avatar
gburke1
Default Short (60') Times
Is 1.969 a good 60' time for stock tires/suspension/stock TC/auto trans? Just wondering if I could improve on this much or if I am already at the outer limits of this setup.
I have some 4.10's coming so I am probably going to have to relearn my launch too, which I am not really looking forward to...
Old Feb 10, 2009 | 09:36 PM
Johnboy7701's Avatar
Johnboy7701
I pulled a 1.9 on stock BFG's...
Old Feb 10, 2009 | 09:43 PM
gburke1's Avatar
gburke1
You have a 5 speed though right? From what I've seen in everyones sigs 5 speed seems to be more capable of better 60' than people with Auto unless you start to get into Aftermarket Torque Converters and stuff.
Old Feb 10, 2009 | 09:44 PM
EagleStroker's Avatar
EagleStroker
I think that's true because you can ride out the clutch. I pulled a 1.8 with my 5 spd on stockers
Old Feb 10, 2009 | 09:48 PM
Johnboy7701
Yeah I only went a couple times but yeah its a 5spd... imagine the troubles Im gonna be having in June when I go to the track the 1st time since the S/C install and 4.10 gears on stock tires... I need some DR's for this summer...
Old Feb 10, 2009 | 09:52 PM
gburke1's Avatar
gburke1
I might see if I can best it this weekend if the track ends up being open. If I remember right though, that 1.969 was launching it as hard as I could on the stock TC with almost no wheelspin, but maybe there is a little more in the stock TC.
Old Feb 11, 2009 | 11:10 AM
gburke1's Avatar
gburke1
Any Auto guys care to chime in?
Old Feb 11, 2009 | 11:41 AM
99GTvert's Avatar
99GTvert
is my username.
That's a pretty great time. What tire PSI did you use?
Old Feb 11, 2009 | 12:03 PM
gburke1's Avatar
gburke1
I believe this was around 30 PSI. I am going to try dropping the PSI down to about 25 next time... also this was with a burnout and going through the waterbox.
Contrary to what a lot of people said the water box + burnout seems to be bringing down my 60' a lot from mid 2.0s down to mid 1.9s. But basically trying to figure out if there is more room for improvement with these tires.
Old Feb 11, 2009 | 12:31 PM
Sidewayz6.0's Avatar
Sidewayz6.0
It's contrary to everyone that hasn't been down the drag strip. They'll always tell you not to do a burnout with street tires. You've gotta take some of the advice in here with a grain of salt.
A little heat will help any tire hook up. Just don't melt them off.
Anyway, thats a pretty good time over all with what you've got done to the car. Exhaust and a tune is turning out 13.0's with an automatic? I'm impressed. Get yourself a big converter and a drag radial, and you'll probably knock another 1/2 second off.
