Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Broke 12s!!
Old Mar 3, 2009 | 09:50 PM
03_svt_cobra_22's Avatar
03_svt_cobra_22
^^^ agreed! lol
Old Mar 3, 2009 | 09:58 PM
fazm's Avatar
fazm
Originally Posted by white07
I am running bias plys. They have a little sway in them when you start going faster b/c the sidewalls arent stiff like a street tire. To add to that the wind was blowing kind of from the side and I think that just helped push my rear end out some more. Also the track isnt a very wide track so I was close to the wall to begin with.
i run bias ply too.
im assuming you are running a radial up front? its likely whats causing it. you will get use to it and stop getting out of it. just wait til you start trapping 120+ it starts getting really fun
Old Mar 4, 2009 | 09:35 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
congrats !
Old Mar 4, 2009 | 09:40 AM
buster's Avatar
buster
congrats - i like the black on the white
Old Mar 4, 2009 | 09:00 PM
white07's Avatar
white07
Originally Posted by Mishri
cold weather explains it.. what was your DA? (I can figure it for you if you give me date/time/location) cold weather makes traction worse but more HP so double whammy
the track is a little above sea level. It was on the feb 28th, around 7:30-10:30, sealy tx
Old Mar 4, 2009 | 09:02 PM
white07's Avatar
white07
Originally Posted by fazm
i run bias ply too.
Yeah ive ran 5 times prior to this with the bais ply but the track I did that at was alot wider so i wasnt as worried but this track was pretty narrow. Im looking into doing 15s all around so i will get some skinnies pretty soon.
Old Mar 4, 2009 | 09:04 PM
white07's Avatar
white07
Thanks. Im think about changing it. I kind of want to go back to a stock look to make it kind of a sleeper once i get the zex kit spraying.
Old Mar 4, 2009 | 09:14 PM
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
not bad, not bad, car probably has more left in it
i ran the time in my sig with cai/tune, mufflers, and mickey thompson e/t street radials (275/40r17) with nothing else; your car has more in it i think
btw what shifter do you have?
Old Mar 4, 2009 | 10:14 PM
white07's Avatar
white07
tri-ax. I need to adjust it so it will be a little shorter.
Old Mar 5, 2009 | 06:13 AM
Hlistr_07RR's Avatar
Hlistr_07RR
I always jizz first
Sweet times, congratulations. I hope to get the chance to make it to a track this summer sometime :S
