Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
TC or Slicks
Old Mar 4, 2009 | 01:02 AM
mikeysGT's Avatar
mikeysGT
Default TC or Slicks
i was just thinking if a TC would have any effect on my ET's right now... I'm pulling 1.5-1.6 60' launching at the stock 2k rpms. I was having some traction problems at the line this past weekend and i think it's cause my tires are from 06. I talked to the M/H guy who was at the track and he told me i should probably get some new rubber first. I'm going to follow his advice and go with some new m/h's but after i do so, i'm thinking of finally swapping the stock converter for a 3200 PI converter. Do you guys think it will make a difference in my 60' times as well as my 1/4 mile times? if so how many tenths?
Old Mar 4, 2009 | 03:00 AM
2000AZ5.0GT's Avatar
2000AZ5.0GT
for a second I thought you meant Traction Control, but no, a Torque Converter will do alot for you. When I bought my car it had a Performance Industries Torque converter, and that thing was awesome.
I'd say go for it. You won't get much use out of the slicks without a higher launch RPM.
Old Mar 4, 2009 | 04:54 AM
Stkjock's Avatar
Stkjock
Retired Mod
Mike-
I think with a good TC you could get consistent 1.4x 60's and that would probably cut your ET by .2-.4
Old Mar 4, 2009 | 07:12 AM
jRock617's Avatar
jRock617
Those Scion's arent really that fast, id say go with new slicks....
Im joking btw...
Old Mar 4, 2009 | 08:02 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
get a TC, if your already cutting 1.5's you not going to lose ET, launching at a higher RPM. a 32-3800 stall would be fine for street just make sure you get a trans cooler to keep the trans a optimal operating temperature.
Old Mar 4, 2009 | 10:45 AM
mikeysGT's Avatar
mikeysGT
I'm talking to PI and hopefully I can work out a deal for the 3200 stall. I'm getting a good deal on some new dr's then ill def be going with the TC. Only thing I'm thinking is maybe I should go with a wider
A wider dr instead of the one I'm using.
Old Mar 4, 2009 | 10:53 AM
USMCrebel's Avatar
USMCrebel
why would you need wider DR? what are you running now?
Old Mar 4, 2009 | 11:03 AM
mikeysGT's Avatar
mikeysGT
275/50/17 on a 17x8 stock rim. I was having traction problems this past weekend after the 1.56 60' with a few 1.8's a 1.99 pass.
Simon1's Avatar
Simon1
I would be more concerned with the compound. A real slick will be a little softer. I'm going to try bias plys from MT to see how they work.
Old Mar 4, 2009 | 11:12 AM
mikeysGT's Avatar
mikeysGT
I'm thinking maybe getting a pair of 17x10's for the rear and going with a 325 m/h
