Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Finally a good one!
Old Mar 8, 2009 | 08:09 PM
  #21
Stone629's Avatar
Stone629
Originally Posted by mustangcat
Stock, it's a 13 flat car. AWD, turbo, and lightweight mean it's a piece of cake to launch. Although with any car it's hard to find a proper driver. There's a guy here with one that's proud out of his mind because he ran a 14.1 1/4 mile.
13 flat stock is a bit generous, more like 13.5 at 102-3 mph with good driver. They're a lot harder to launch then people think. You can't just rev the **** out of them and dump the clutch and expect a good launch. Definitely one of my favorites cars though.
Good run OP. You got a sick ride.
Old Mar 8, 2009 | 08:40 PM
  #22
mustangcat's Avatar
mustangcat
Deputy CatDog - To Purr'tect and Explode
Really? I assumed that since it had AWD all you had to do was not spin out like crazy to get a good launch.
Old Mar 8, 2009 | 08:46 PM
  #23
Stone629's Avatar
Stone629
They'll drop out of their powerband if you dump it to fast. It'll spin some, but then it'll regain traction and bog. You got rev it to whatever the best RPM is for those cars, then come off the clutch smoothly, but quickly, keeping the RPM up. Its pretty easy to screw up.
Old Mar 8, 2009 | 08:48 PM
  #24
EagleStroker's Avatar
EagleStroker
For sure. You dump the clutch on them and they wheel hop like a ****, you gotta be able to drive one.
Old Mar 8, 2009 | 09:09 PM
  #25
83gtragtop's Avatar
83gtragtop
Not only do you have to know how to launch it but you need to have the guts to do it. Those high rpm launches can really do a number on your clutch.
Old Mar 9, 2009 | 09:10 AM
  #26
S8ER01Z's Avatar
S8ER01Z
x2... and the clutch doesn't like it much when people do launch like that...I know a kid that was running low 13s with his stock...put in 2 or 3 new clutches and ended up doing a trans rebuild in the 2 years he had the thing. I just turned 105,000miles and still have the original clutch.. couldn't imagine going through them that quick.
Old Mar 9, 2009 | 09:16 AM
  #27
AmericanSpeed's Avatar
AmericanSpeed
Eagle, What engine compression are you running? I'm assuming it is stroked to a 298?
Old Mar 9, 2009 | 06:16 PM
  #28
EagleStroker
An .011 over, 301 1/4" so basically a 302. I'm running a 9 1/4:1 compression, so a lower than stock compression and blower style cams, not bad IMO.
Old Mar 9, 2009 | 06:46 PM
  #29
Big50's Avatar
Big50
How much did your set up cost you? I am want to get to around your numbers and would like to stay N/A.
Old Mar 9, 2009 | 06:50 PM
  #30
EagleStroker
PM sent.
