First time at the track on the bottle.
Before I start, the track is in Morrison Colorado. Bandimere speedway is the highest elevation track in the US I believe. The elevation is 5880ft above sea level. The DA (density altitude)for my best run was 8150.
http://www.youtube.com/watch?v=UIgPh_J3fa8
break down of the time slip.
60' 1.94
330 5.68
1/8 8.79
MPH 78.88
1000' 11.45
ET 13.67
MPH 101.94
this was at 8:18pm at night, DA was still 8150, average is 8400DA so it was pretty good last night.
(13.6@101 corrects to a low/mid 12 second 1/4 mile at 110mph at sea level)
'Vert was on a 100shot, The car ran STRONG last night. felt good. first pass on the bottle was with 8* of timing, and i babyed it out of the hole, which showed in the 2.3 60' when with NO nitrous i cut a 2.0 60'
Here is some video's we shot to compare my car to at this elevation.
2010 Camaro SS
(yes, it's a SS)
http://www.youtube.com/watch?v=hEGG5hlqlCY
Mach 1, slick's and nitrous, unknown other mod's.
http://www.youtube.com/watch?v=tunqfFmFK3c
So in comparison, my car move's out pretty damn well. That is with STOCK heads, and STOCK cam.
This winter the convertible will receive these.
Also a trick flow stage 2 cam.
Spec's of the trick flow stage 2
Basic Operating RPM Range: 2,500-6,000
Advertised Duration: 286 int./294 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.542 int./0.563 exh. lift
should put the car in the 12's up at this elevation
thank's for looking!
60' 1.94
330 5.68
1/8 8.79
MPH 78.88
1000' 11.45
ET 13.67
MPH 101.94
2010 Camaro SS
(yes, it's a SS)
I run 15's off the bottle, and even though i have stock heads and cam, i still weigh less, and im set up more for drag racing.
so no, there not SLOW, but there not as quick as i though they would be. Low 15's up here at this elevation is equal to mid 13's at sealevel.
off the shelve cam is because i know they work well, dont need anything gnarly, and know the trick flow cam's seem to work great.
also trying to do this a bit on the cheap side
Thank's! Yea i was talking to a buddy and it just seemed dumb to not put in a cam while throwing on the head's as your already "there" pretty much. lol.
12's with no bottle with the head's and cam.
but at high elevation you break **** less often, and you get better gas mileage. lol. I plan on returning to some sane elevation within the next 5-8years i hope.
