Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
TIMES/HP
Old Jul 22, 2005 | 05:10 PM
af41's Avatar
af41
Default TIMES/HP
94 cobra
3.73s
70MM Granatelli Mass Air
MSD wires, coil and 6A box
CAI
B&M Short throw
Superchip
Havent had time to take it to the track. Any ideas on HP output & what numbers it will run in 1/4 mi? I am man enuf to handle the truth.....
Old Jul 22, 2005 | 07:12 PM
Quik's Avatar
Quik
Default RE: TIMES/HP
why did you buy a 70mm Mass air when cobras come with them stock?
youre basically stock. figure it could be range from 13s to 16s
Old Jul 22, 2005 | 07:41 PM
af41's Avatar
af41
Cuz I was told cobras had a 65 mm MAF....
Is it worth port/polishing the gt40 heads or just look to put aluminum?
Old Jul 22, 2005 | 08:30 PM
Quik's Avatar
Quik
93 cobra had a 70mm maf. its basically the same setup as yours. so i would assume you had a 70mm. and if you were going ot upgrade i would of went a little bigger to atleast a 73mm
yes it would be worth it to them PP. only advantage of aluminum is wieght
Old Jul 22, 2005 | 09:54 PM
af41's Avatar
af41
at what point does a 5.0 need tuning? Do they just adjust the timing? I've heard that sn95 computers have a bad "load" and that a tune can help. I don't want to waste my money if it won't do much for some basic bolt on mods though..
Old Jul 22, 2005 | 10:26 PM
Chris98Formula's Avatar
Chris98Formula
ORIGINAL: Quik
Wouldn't that cause the car to run lean? It would be taking in more air than than the computer thinks it is taking in, I know it does that on LS1 cars. It might be best to just get a larger recalibrated MAF.
Old Jul 22, 2005 | 10:38 PM
af41's Avatar
af41
i checked the MAF and it is a 75MM...what about the tune? will it do much for my mods???
