Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
when racing......
Old Jul 28, 2005 | 09:23 PM
eclipsegt's Avatar
eclipsegt
Default when racing......
when you are racing with a 5sp wut rpm's do you usually go before u switch gears? someone told me to redline it but i wasnt sure if thats the best way
Old Jul 28, 2005 | 09:29 PM
01GT's Avatar
01GT
I ♥ Acer
Default RE: when racing......
Depends on your car.
idriveamustang's Avatar
idriveamustang
depends wut type of car you have... you usally wanna shift a little over the powerband so you land right on it when shifting into the next gear. It would help if you got your car dynod And then you can tell from there. I usally shift at around 4800 when racing cause my NoN-PI heads suck.
Just my .02
Old Jul 28, 2005 | 09:49 PM
Guest
Guest
Posts: n/a
I shift at 7700 rpm. [8D]
Old Jul 29, 2005 | 01:17 AM
99saleen351r's Avatar
99saleen351r
Shift at redline, most cars that ar raced shift at redline
Old Jul 29, 2005 | 01:51 AM
Guest
Guest
Posts: n/a
ORIGINAL: 99saleen351r
Some don't.
Take mine. Peak power is 7600 rpm, redline is 8000 rpm. That extra 400 rpm is my power curve actually falling. You're actually slowing down slightly if you're still going after peak power. I bought a shift light with a 7600 pill which I will eventually install under the dash to where I can see it out of the corner of my eye.
accuracy + light + good shift point = best times
Old Jul 29, 2005 | 08:58 AM
nanaki's Avatar
nanaki
Retired MF Moderator
i don't shift at redline, i shift a little before. about 5000 - 5200, which is when i stop making power.
Old Jul 29, 2005 | 01:41 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
my car has a redline of 6750, fuel shutoff @ 7000. i shift at 5700 where the powerband levels and starts to drop.
Old Jul 29, 2005 | 03:49 PM
99saleen351r
ORIGINAL: 2000Si
Some don't.
Thats definatly true but most stock cars(minor mods) that havent been dynoyed your just better off shifting at redline.Oviously you can shift anywere.Peolpe who race no whats best for there car but in any old situation I would shift at redline.Keeping the car in its power range will oviously make it fastest that way
Old Aug 2, 2005 | 03:05 AM
Zoie_daGT's Avatar
Zoie_daGT
I shift at about 5100 rpms. My Non PI heads and intake run out of air pretty good after that.
